My GE Profile Washer WPRE6100G0WT shakes violently during the spin cycle. It does this so much that it appears as if the machine is going to fly apart. I check the dampening straps, the balance ring, and the rod and spring assembly. I also checked to make sure that the outer tub was screwed on to the metal supports. Any help would be greatly appreciated!!
SOURCE: Shakes Violently
run it with the top access panel open and watch,
while you are there try out the suspension ,
you do it like an old car push it down , push to sides etc .
it should resist and return well. no bounce. tight.
SOURCE: GE WBVH6240
All,
There are three screws under the plate beneath the door. Remove these three screws and remove panel. Immediately you will see a removeable plug about 2 1/2" in diameter made of white plastic. This is where your problem lies (or at least one of them). CAUTION - before you remove this plug, put a bucket under it because water will come out. After you unscrew the plug completely, pull it out toward you. You will no doubt find many items that washed out of your cloths. I found legos and coins tangles up with strigs and lint. The entire area was completely plugged. The coins were probably the source af the stains we had on our cloths as they were all black from the water and soap.
The pump on mine burned out and I am trying to replace it. Then I will sell this junker.
I hope this helps some of you. Please advise.
SOURCE: GE Profile Washer leaking underneath during spin cycle
its your outer tub it has a hole in it
SOURCE: My GE WCVH6800 washer shakes during the spin
sounds like the shockers have went
http://www.repairclinic.com/SSPartDetail.aspx?s=t-+GE+WCVH6800+-%3d%3di1264427&PartID=1264427
SOURCE: My GE Model # WBB4500E1WW washer not spinning
the washer is on but not spining and the machine is about 6 month old
