I have a frigidaire front load washer end it always stops before the spin cycle and displays E20. The tub also has alot of water in it when it stops. I HAVE TO PRESS CANCEL AND SET THE WASHER TO SPIN ONLY for the wash to finish.
Turn program knob to spin and hit start then hit cancel within 5 seconds hold down options and start/pause button this will put you in the self daignostic test
Turn the program knob (1) click clockwise from the
start position. The hot water solenoid will activate
and hot water should enter through the detergent compartment
Turn the program knob (2) clicks from the start
position. The bleach water solenoid will activate and
cold water should enter through the bleach compartment
Turn the program knob (3) clicks from the start
position. The bleach and the wash water solenoids
will activate and cold water should enter through the
softener compartment.
Turn the program knob (4) clicks from the start
position. The door lock solenoid will deactivate and
the loading door can be opened.When the door is
opened, the drum light should turn on.
Turn the program knob (5) clicks from the start
position. The washer will fill and tumble. Once
tumbling has started, the Boost Heater (if so
equipped) will turn on.
Turn the program knob (6) clicks from the start
position. The drain pump & door lock solenoid will
activate and the washer will operate in high spin.
then on the last turn it will give you the other error codes it has that code is giving usually is caused by a different code to clear the codes
• Turn the program knob clockwise 7 clicks from the
Start Position. The control will signal the last error
code.
• Press and hold the Options and Start/Pause
buttons for 3 seconds. The code will be cleared. you really need to clear that code first to do the test but it can be done in the daignostic test skip the rest first go straight to the 7 clicks and clear the code but dont open the door during the test otherwise it will give that code after you get it cleared go to the spin spot on the knob and keep turning clock wise to go through the test but give it at least 3 seconds for each test then it should display a different code and what ever it is email me and i can help you out at that point [email protected] i have alot of experence with appliances
