The screen has flickering color snow on all inputs. It even shows when the TV has no inputs connected. I posted some pictures here:
http://picasaweb.google.com/lh/sredir?uname=Williams4895&target=PHOTO&id=5344310343255213490&aid=5344310225482559633&authkey=Gv1sRgCP_RtKaJycaBYQ&feat=email
It looks like there is a defect with the main control board you will need to get it replaced.
Hello williams4895,
I have seen this problem before, it is caused by RF interference. For it to be this severe it appears that it is an internal RF issue which means that there may be problems with high frequency signal decoupling capacitors used to decouple RF/IF signals from the power supply that feed said such stages of the TV. This is going to require that you use an oscilloscope to determine if RF/IF signals are present on the power supply rails. However this is looking like according to your pictures as the problem I am describing. In this case it will be a slow process to determine the cause of the interference, since it may involve more then capacitor, and maybe you catch a break and it might be due to one decoupling capacitor.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
This is a decoder issue and the decorder would need to be replaced or fixed, I can give you some information on where and whom www.teexp.com you can check them out, However if you do have a warrenty or you bought this tv within 30 days I would be taking this back to the store. Otherwise if its rather out of warantee I would check out that link above you be glad you did!
Thanks
Rulds2008
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Hi
this is Radio frequency issue RF Xformer, the Video RF is defective maybe this is lost contact or damage the magnet core. no other only in RF section.. sir if you have knowledge in electronics repairing and have tools equipment for electronics i can teach you how to fix this problem...
Thanks
HI and by the way iam abhishek,
i think the problem is with one of these three components and i am sure ,,
1.An jungle IC on D-board
2.colour wheel
3.CRT tube
please check these three and repair it..if u dont have electrical knowledge about tv(soldering etc...)better to go for a tech..
thank u,,if u found this helpfull please rate it///
Thank you, I am experienced in electrical repair (soldering, etc...). However, for this equipment, I do not know how to check the 3 items you mentioned. What steps do you recommend?
Great. I have repaired electronics and another TV using instructions from FixYa expert. I have most of the tools and can get the ones I dont have. How do I start?
I posted the pictures to the same location as my original pictures. I posted pictures of the power supply and detailed pictures of the mainboard. There are 2 boards that you can see on the side of the main board of the TV that I didn't include. They are under a cover that I didn't remove. Please let me know if you need pictures of these also.
Thanks,
Shawn
I would like to resolve this quickly. Will it be easier to replace the mainboard (or the power supply board)? If so, where is the best place to buy one?
