Autofocus failure on my lens.Takes ages to autofocus and when it does for example @ ISO100,F2.8 in the hot sun I get a 15 second exposure .Can you assist please ?
My experience with lenses is that they either work or they don't. If it does not work "as you usually used it", then there is a problem inside the lens and not something the average photographer can repair. Lenses are quite fragile, a slight knock on one occasion can damage the inner bits which are very intricate and more so with motorised lenses. I have experienced a battery problem error message through a damaged lens housing and the battery also subsequently got damaged through short circuit inside the lens mechanism. Send it for a check-up and repairs!
SOURCE: I just bought the Tokina SD 12-24 F4 (IF) DX
Only the MkII version of this lens has an autofocus motor built in, the MkI relies on a motor in the body of some Nikon AF SLRs to autofocus. The D70 does not have an inbuilt AF drive motor, so if you have the MkI lens then you can only use it in manual focus mode on your camera.
