When I start my Xbox 360 and it is cool (the first minute) it works perfectly but by the time it loads the game and it heats up, it freezes. When I turn-it off to restart, it restarts but display the screen that it cannot read the disc, asking to clean it. If I let it cool down for 1 hour and restart, I get the same story. Read disk first time, freeze, restart and cannot read disc.
I put a DVD in it. It played the movie for around 5 min. and when I played with the controller, it freezes.
I never got the famous red ring light problem.
SOURCE: xbox 360 freezing
Also check to ensure that your console has good airflow. The console itself may be overheating if there are too many objects near it blocking airflow.
SOURCE: 360 freezing up
Over heating wont turn on
http://forums.xbox-scene.com/index.php?showtopic=599216
http://forums.xbox-scene.com/index.php?showtopic=606431
http://copronymous.com/wp-content/uploads/2007/05/fix-for-the-3rlod.pdf
Clean your disc, and keep objects away from the sides and back of the console... to allow cooling. Also might want to consider getting a cd lens cleaner, it'll get the dust out of there.
SOURCE: XBOX 360 FREEZES WITH OUT RROD?
your drive is out or fimware corrupted just check the hardware and flash your console
SOURCE: xbox 360 red rings freezing
the red ring of death means you have a bricked XBOX.
something has
gone wrong with the hardware inside, and you need to take it back to
the shop you purchased it from, so they can replace it under
warranty.this is not an unusual problem to encounter, but
unfortunately, can only be repaired by qualified repair specialists.
the best they can do for you, is either swap out the hardware and give
you a new box, or they send yours away and you wait the 4-6 weeks for
it to be repaired and sent back..
cannot play disks
