The website says i need latest version of flash player but when i try my ps3 says i have the latest i've reset the system and have chosen run the pluggin but says i need to update everytime
SOURCE: ps3 not working
Is there sound? If so, then maybe your video settings got mixed up. Try the video reset.
When the PS3 is in standby mode (red LED lit), hold the Power "button" until it beeps for booting, keep holding until it beeps again (not to turn it off).
If done correctly you should see something again (480p resolution) allowing you to change settings.
I hope this will help you out.
Greetings,
DarkNeogen.
SOURCE: ps3 system update data corrupted
Hook up the external to your USB port and copy everything over. I had to do that when I installed a larger hard drive in my PS3
SOURCE: keep gettin error code 80710723 when updating system on ps3
mae your playstation 3 wired then download it. once downloaded then go back to wireless.
SOURCE: PS3 blackscreen, but sound! tried all common tricks to reset!
try getting a freid or someone you know to go through with you to try and change resolution of screen. i did this to help someone. doesnt work well but worth a try
SOURCE: I have installed VidZone but it needs to update
restore the ps3 to manufacturers settings (wipe it) or dont use viszone
Start your PlayStation 3's web browser. You can do this by navigating to the "Network" category on your PS3's main menu and selecting the "Internet" option.
