Model no is JGBP26GEN2AD. When I keep the knob on "LITE", no clicking sound comes. But the gas is flowing thru all 4 burners properly. I can use the burners if I light a match. This is happening with all four burners.
Everything else is working fine.
Thanks.
- Sam
SOURCE: Gas Flow
suspect problem is with the regulator on the gas bottle as it would be unusual for all burners to be faulty at the same time. try substituting a new regulator
SOURCE: When I attempt to light
u can solve this problem by cleaning off the igniters. first of all unplug it from the power. Then take a small wire telcom pic tool to scrape the white and brown deposits from the sides of the igniters. You could probably use something else similiar to do the scraping. I noticed a shiny surface underneath. then go ahead and scrap it and brushed clean the mating surface where the spark travels. then vacuumed up the mess. your burners all worked great after this.
or
Turned off the power, removed the five knobs and corresponding rubber rings, and used a hair dryer on the five holes where the knobs were for about ten minutes in total. Hey presto, when I turned the power back on.
Yes, the moisture is probably the problem...
Here
is a tip that I wrote that will help figure out why the burner spark
keeps on clicking...
Gas Range Repair Burners
Keep on Clicking
heatman101
When you say everything else working fine, do you include the oven, broil, and the clock, or just the burners when lit with a match?
