If you are using an Apple iPad and are having trouble accessing your saved items on Facebook Marketplace, there are a few things you can try to troubleshoot the problem:
Clear cache and cookies: Clearing the cache and cookies on your iPad can often resolve issues with apps like Facebook. To do this, go to the Settings app on your iPad, then select Safari. Scroll down to the "Clear History and Website Data" option, and select it. Confirm that you want to clear the data, then try accessing your saved items again.
Update the Facebook app: Make sure you are using the latest version of the Facebook app. Open the App Store on your iPad and check for any available updates. If an update is available, download and install it.
Restart the app: Try force-quitting the Facebook app, then reopen it. To do this, swipe up from the bottom of the screen and pause in the middle of the screen to see the app switcher. Swipe left or right to find the Facebook app, then swipe it up to quit. Open the app again and see if the saved items are now visible.
Contact Facebook support: If none of the above solutions work, you can try contacting Facebook support directly. You can usually find a "Help Center" or "Support" section on their website, which may have resources for troubleshooting specific issues.
Remember, if you are unable to access your saved items on Facebook Marketplace, you can also try bookmarking the pages of individual items you are interested in to access them later.
Delete the Facebook app from your iPad (press on its icon until it quivers, tap the X to delete it, tap the home button). Then, open the App Store application and tap Purchased. Find Facebook and re-download it. You'll be asked to log into Facebook with your user ID (email address?) and password to continue.
it may be like a phone once you have set up an account to sign into it automatically stores that 1, so u would need to set up another log in account manually & then when u attempt to log in it will ask which 1 u want, if you cant set up more than 1 account, then u have to manually delete yours & then use his.
Try logging out from Facebook from inside PPS, do a restart on the iPad (hold down Home and Power button together for 10 seconds) then start PPS and connect to FB. If that doesn't work, delete the game and reinstall it. (This is standard troubleshooting for most apps)
ARE YOU SURE YOUR NAME AND PASSWORD IS RIGHT? DOES FACEBOOK HAVE SOME SPECIAL QUESTIONS TO IDENTIFY YOU ....MAYBE YOUR HOME PHONE # IF NOT YOU MAY HAVE TO OPEN A NEW FACEBOOK ACCOUNT WITH A NEW NAME AND PASSWORD
Just a thought as I just experienced this myself: I wasn't aware that the applications on my ipad run in the background. So when I tried repeatedly to connect - each attempt was opening a new log in to Facebook. Once I learned that I had a number of background apps running - multiple times, specifically about nine Facebook entrances - I closed them all and was able to log in immediately. I'm not sure how something very simple (turning all these apps OFF - slipped by me.) If you wish to check: double click on your top / screen side, power button. Running apps will either have a red 'X' - older ipads, or have a 'mini screen' (each for all open apps) that you can 'swipe' off. On mine it's "up". This may not be what is causing you trouble but it was an instant 'fix' for me. Hope it helps - let us know? Thanks & good luck.
Be careful that it's not a phishing attempt, and that the message really is from Facebook. If you're sure it's kosher, my best advice in a case like this--ask a knowledgeable friend, or one who knows a tech-type person, to go through the password reset process with you in person. You can have him (her) look away when you enter your new password. If he's brought a pad or tablet along, try logging on to Facebook with both your iPad and his to make sure the new password works.
Make sure no one else is logged into the Facebook app, then put in your info and log in. If that doesn't work, you'll need to reset your password through Facebook in a browser.
