Question about Sharp AR-5316 Advanced Digital Imager Copier
5316e reset code - Sharp AR-5316 Advanced Digital Imager Copier
  • Sharp Expert
  • 414 Answers
# -interupt-c-interupt
Posted on Feb 13, 2014
6ya staff
SOURCE:
MY SHARP AR-5316E DISPLAYS H4 AND IS NOT WORKING
Dear friendscom, H4 :Heat roller abnormally low temperature.
__ possible cause __
  • Thermistor failure
  • Heater lamp failure
  • Thermostat failure
Perform the following procedure to reset the code:-
"#" key-- Interrupt key-- "C" key --Interrupt key--14--print
Jan 12, 2011 | Sharp AR-5316 Advanced Digital Imager...
My sharp AR-5316E Displays 4 H and nothing else, how do i solve it
You must reset this code.
#-interrupt-C-interrupt
or C-photo-C-photo, Press 14 press start key.machine is ready.
If heater lamp was burned out you replace it.May be it problem on over temperature.
Jan 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
My AR-5316E copier is displaying this error code H and 4
Your heater lamp maybe busted.
Use the simulation 14 to cancel the error..
If nothing happens then you need to check your heater lamp.
Oct 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
I have sharp AR-5316E copier, the indicator is
it is the problem your copier fuser unite problem thermostater or heat roller is over temparature . You press # interrupt c inturrupt then 24 press print key 00 then machine is of after on is ok
Jul 13, 2009 | Sharp AR-5316 Advanced Digital Imager...
H4 error for sharp ar-5316e
Try reset the code by pressing [#] [Interupt] [C] [Interuptr] [14] [COPY/START]
If error still exist, check the thermofuse and the heater lamp
Jun 22, 2009 | Sharp AR-M205 Copier
Sharp AR 5316 E photocopier error clearing
Try reset by pressing [#] [interupt] [C] [interupt] [1] [6] [start]
May 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR 5316E
i want a driver for charp ar-5316e
Oct 28, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
32 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
