I have a HP DJ 6122 as my workhorse printer. I change my black cartridge in and out with a new one and old one depending on what needs to be printed (official vs. scrap). Each time I change, it prints a test page. I want to turn this function off, as it wastes the color ink. Is there a way to do so?
Yes.Tell it to print a dot short word and when it starts printing unplug the power cord so it stops with the printhead somewhere to the left. Then do your cart change. It won' t know you did anything.
The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with your Windows XP and Vista systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch. I wet and slap stubborn old ink cartridges to un-stick dry jets. sometimes I use a small clear silicone tube to suck a bit of ink to get them started as the jet holes need priming sometimes if they are old.
SOURCE: HP K550 blak print failure
Hold the far button on the right down for a minute and it will move the head over for access
SOURCE: auto test page on the HP F 380
I don't know this personally, but you should be able to hit the power button and turn it off right after you load the cartridges. then power back on. That might do the trick.
SOURCE: new tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
SOURCE: HP L7590 black ink printing poorly even with new HP cartridge
I have had the same problem It is the print head not the cartridge If your printer is still under warranty have the printhead(s) replaced if not Open the unit where the print heads are and hold the OK button for 5 seconds. The Print head carriage will move to the left
Carefully remove the KY (Black & Yellow) Print head with a cotton swab and alcohol clean the contacts and replace the printhead. If this does not work remove the printhead and then with a spray bottle spray the nozzle area on the bottom (DO NOT TOUCH THE NOZZLES AS THEY WILL BE DESTROYED) HP techs have told me this will void any warranty so act accordingly I use a printhead cleaning solution available from most any online ink supplier
Replace the printhead after it has dried out (less than a minute). The printer will then go through an alignment cycle and should print I had to do this several times before the print head performed as it should
SOURCE: Photosmart 5580. How do I turn off the annoying
Because it is a photo printer it knows that the print heads must be aligned for optimum reproduction. You get a new print head with each cart.
For the amount of ink a test page uses I can't see the reason for complaint. If you begrudge the miniscule amount of ink and are not bothered about the best possible printing then just ignore it.
