Nordic Track NordicTrack Treadmill, A2550 Logo
A
Anonymous Posted on Feb 06, 2014
Nordictrack a2250 powers on and off motor only runs for a second
4 Related Answers
Anonymous
  • 218 Answers
  • Posted on Aug 11, 2010
SOURCE: my nordictrack a2250 only beeps
the console software is damaged and the console will need replaced
Anonymous
  • 218 Answers
  • Posted on Aug 13, 2010
SOURCE: My nordictrack a2250 turns on, the incline works,
the motor controller is bad and needs replaced
Anonymous
  • 20 Answers
  • Posted on Nov 09, 2010
SOURCE: i have a nordictrack a2250 when run on it the belt
If your treadmill has had a lot of use, the belt has probably stretched and needs replacing. You can order a new one at Treadmill Parts
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Nov 29, 2012
SOURCE: When I plug my Nordictrack A2250 in the fan runs and the screen is blue, none of the buttons work. This is without the safety pin attached.
Adjust the REED switch, test it, clean it, and tight the plug or connector very well.
2) replace batteries with the same type, same mark, same polarity
3)clean contacts spring with c. cleaner spray. buy it from some electronic store.
God bless you
My NordicTrack A2250 treadmill display is flickering. The unit runs perfectly well. Can this be repaired?
Hey Alfred, yes it can be repaired,,, but in the interest of saving $$$$,, if it runs... just jump on and go until you have had enough... the rest is really trivial..think about it..
Why does motor run about one second, then shuts down?
If you wish to get some details; check the site linked here. Pull up older posts. Surf for article abort treadmill.
http://electro-medical.blogspot.com/
God bless you
1helpful
Nordictrac a2250 beeps when key is attached
adjust the reed switch first, and after RUN the software calibration for diagnose and troubleshooting. see the diagram
God bless you
4helpful
3answers
I have a Nordictrack exp 1000x and it won't turn on. Any ideas?
Right next to the power cord is a circuit breaker. Check it to be sure it has not tripped. If so, reset the breaker.
Check the outlet, be sure there is power.
If that checks out, remove the motor cover (unplug the machine from power first) and check the fuse on the controller board. Chances are if the fuse is blown, the controller might be defective. Replace the fuse and try the machine. If it blows again, the controller is defective..
I have a nordictrack a2250 when run on it the belt slips i need to tighten the belt
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
