My cooker has power to it all the fuses have been tested but none of the elements or oven will come on how do i reset it or turn it on ? is it somthing to do with the timer ?
SOURCE: ovens on cooker
DEPENDS ON THE MAKE AND MODEL EACH TIMER OPERATES DIFFERENTLY, BEST SOLUTION IF YOU DONT USE THE AUTO FUNCTION IS TO HAVE THE TIMER WIRED OUT SO OVEN COMES ON REGARDLESS IF THE TIMER IS SET OR NOT.
SOURCE: How do I reset the clock on a shacklock multifunction oven?
press timer (picture with bell) adn cooktime ( picture with what looks like steam above a square) buttons simultaneously while turning adjacent knob clockwise until readout registers current time. Release both buttons and clock is reset.
SOURCE: Owners Manual Franklin Chef Slow Cooker
I broke the power control button on my cooker. Can I buy a replacement button and if so where.
SOURCE: Hi, the oven is not
If the element is okay and the element and fan aren't working together then it will be a problem further up the line. The next question I would normally ask is is the electronic timer in manual mode. When you turn the oven on does the oven indicator light come on?
