It sounds like you are having trouble using your Panasonic VDR-D150 camera in PC mode. Here are a few things you can try to troubleshoot the issue:
Make sure that the camera is properly connected to your computer via the USB cable. Check that the camera is turned on and in PC mode. Check that your computer recognizes the camera as a device. You can do this by going to the "Device Manager" in the Control Panel and seeing if the camera is listed under "Imaging devices." If the camera is not listed in the Device Manager, try unplugging and re-plugging the USB cable and restarting your computer. If the camera is still not recognized by your computer, try using a different USB cable or a different USB port on your computer. If none of these steps help, it is possible that there is a problem with the camera itself. In this case, you may need to contact Panasonic for further assistance.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa. Organize edit and share your photos
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Consider NOT connecting the camera to the computer.
Uinstall the software and then reconnect the camcorder via the USB. if this is detected then install to connect.
If there is no detection then the software must be reinstalled and connected. Use a different port to check. shut off the camcorder to connect , if not switch on and connect.
If either wont work then remove the memory card and try if it connect.
If not check if the cam is detected in another PC to confirm the fault of PC or cam.
Generally when you connect the camera via USB Windows XP and Vista activate native drivers and the camera becomes visible under "My Computer" (XP) or "Computer" (Vista) as a removable drive. However, probably will not be visible by capture software. In that case you would need to use a DV interface cable otherwise known as firewire and have the camcorder in playback mode.
I believe you have to use a Firewire (IEEE 1394) cable to transfer the video. From what I have read, the USB connection is only if you want to use the camcorder as a "live" camera.
Use of a USB hub for connection does not guarantee normal operation. Try attaching the USB cable directly from the D-snap SD Camera to one of the built-in USB ports on the PC.
