Tightened everything and fixed the leaks, filled with water only and ran through the system and checked for leaks, no leaks, drained and filled with coolant and water not 50/50. doesn't overheat anymore but heater does not blow hot air after 15 mins. or so
After the engine has reached normal operating temperature, feel both heater hoses going into the firewall. Are both hot? If both are hot, it's probably the door or doors in the heater case not operating from the selector knob on the dash. If only one hose is hot, the coolant is not circulating through the heater core. Look for a water valve in the hoses that is shut. If no valve, crack open the cold line to see if you can start circulation through the core. If neither hose is hot, pull off the inlet to the heater core (it may come from the cylinder head area) and run the engine and check stream flow. It won't spurt out like a garden hose, it should flow out in a smooth even stream, maybe just enough pressure to push a steady stream. If no flow comes out, coolant is low, or there is a circulation problem in the engine, like a kinked hose, a weak water pump...
Does the radiator cap hold pressure in the cooling system?
SOURCE: 91 toyota 4x4 22re overheats on highway, but not at idle.
original issue sounded like thermostat but now that you have lost power i would have to say thermostat, blown head gasket, and warped head
to check thermostat find and remove place in pot of boiling water the see if it opens, then to ice water to check if closes.
the only way i know to check headgasket and head is to check oil and water. oil will have water in it, and water iw have oil in it
SOURCE: Prizm overheats, heater core leaks, no heat
You can bypass the core or fix it that's up to you but I would change or remove the thermostat first. If it still overheats then start looking at the water pump and radiator. Hope this helps. Good luck.
SOURCE: 2000 Xterra intermentantly overheats
sounds more like the thermostat may be failing. generally a water pump starts leaking out of the "weep" hole in the casting before it quits. just look at the front of the water pump for a greenish streak or an obvious leak.
if you also suspect you heater core may be getting plugged now would be a good time to back flush it to get rid of some of the gunk.
