Invacare Supply Group Invacare Pronto M91 Electric Wheelchair Logo
A
Anonymous Posted on Feb 07, 2014
Service indicator flashs 5 times and chair will not move
Invacure Pronto M91 with Sure Step
3 Related Answers
gnsdance97
  • 68 Answers
  • Posted on May 01, 2011
SOURCE: one red light three green flash when turned on
Your chair has a motor problem. The code does not tell which side it is. Make sure both motors have the brakes in the drive position before turning on the chair. Also check that both motors are plugged into the main control module in the base of the chair.
wvgal25
Rhonda Grazulis
  • Posted on Jun 02, 2014
my pronto sure step is flashing 9 times on the wrench and Im unable to turn the chair off. HELP
gmoneydawson
Gary Dawson
  • Posted on Mar 30, 2015
How long does it take to charge batteries on a m-6 pronto
The lights are flashing and it will not do anything. I plugged it in and it shows 2 red lights, 2 yellow , and 4 green . It is moving from left to right since I plugged it in an hour ago.
Make sure that you are charging the chair 12-14 hrs before driving. charge with the joystick on, make sure both freewheel levers are in locked position.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Spj-80, model 1122190. Why doesn't it move?
you may have a current rollback problem you will need to charge the Chair for 14hrs. with the Joystick on! This will reset the circuit. Charge with the joystick on! It is okay it won't hurt a thing, in fact from now on always charge with the joystick on.
What does 7 times flashing mean is wrong on pronto m91
Seven blinks is most often the joystick. A Invacare Remote Programmer can be plugged in to the joystick to verify this.
My pronto m91 was flashing 5 times on the yellow led and after i resert it like you said it ran for a minuet and now it flashes 4 times on the bottom yellow led.
I am new to this request. Hope you have had your chair fixed by now, but in case not. If you still need help I really need more chair information. What joystick? Many different joysticks with different yellow lights. With a 4 or 5 blink it could be a motor or battery voltage problem.
5helpful
2answers
Lights flashing
If your chair is in freewheel (levers on back of motors not in drive) then the light will flash. But are the lights scrolling left to right or right to left? You can check for freewheeling by trying to push the chair from behind if it moves easily then it is in freewheel and you will have to move the levers to the drive position. You need to give more info of the flashing lights are all the lights flashing are only some flashing? etc
3answers
One red light three green flash when turned on
I need help with electric wheel chair batteries for a Pronto M91
after fully charging the batteries I plug in the control and it flashes once and then it is dead and the batteries are in recharge mood?
2helpful
2answers
Pronto 91 fully charged batt but only gey 3 flashes off red light
Batters won't hold charge and work properly it sat up for that long. replace batterys
Top Invacare Supply Group Health & Beauty Experts
Rob Hill
Rob Hill
john h
Steve Pack
Steve Pack
Are you an Invacare Supply Group Health and Beauty Expert? Answer questions, earn points and help others
