I have a hotpoint washer dryer WD51 first edition 1100.
It does not seem to be able to spin properly either, but that could be because of all the water in it?
I have read about cleaning the filter incase it is blocked but I know where to find it - unfortunately I no longer have the manual that goes with the machine.
Many thanks :o)
I have the same machine and mine is unable to spin because of all the water left in it. I have checked the filter (unplug from mains, remove screws and take off back - the fat, black hose coming from the bottom of the drum is where the filter is. There is a black, circular clip keeping the hose on. Emply all the water you can from the drum first. Hold this clip with both hands and carefully move the right side up and the left hand down to open it. The hose will come off but it will probaly be full of water so put a shallow bowl under it. I have found socks in here before now!
If the motor isnt going around then open the lid now the motor is on the right hand side as you look at it now on either side of the motor there is 1 wire going to the inside of the motor these leed to a plastic casing which are your carbon brushes these will need replacing as they will be less than 8ml in length these start at about 25ml in length the way to get them out is by having some bent nosed pliers place either side of the carbon brush and squeeze now pull,pull of the wire now when replacing the new carbons have a small metal bar coming from the side push this up and make sure the carbon brush goes in and out freely they must do this replace in the opposite way from taking out this time you dont need the pliers to replce them
I cant get the plate at the bottom of the front of the machine off where I think the filter is. I've unscrewed the three screws but it seems to be glued on . How do I get this off?
