Question about Clothing
My outlets in bathroom dont work
The lights work, the fans work but the outlets in master bath (plugs for hair dryer/curling iron...
6ya staff
SOURCE:
danasaur
Dana Stienheimer
  • 77 Answers
SOURCE: Modular Home Wiring Schematics
I disagree totally. Nobody wastes copper wire, especially idiots (because they make less money). Thoose extra wires are VITAL. The way to identify them would be to get a long extension cord, long enough to reach main breaker box. TURN OFF MAIN POWER SWITCH TO ENTIRE HOME. Make sure the "line" or "hot" wires are dead (since there are two boxes looped together, this house system may not be dead just from a switch). Once you are sure nothing is hot, use a VtVm to loop through the extension cord to each wire in main breaker box (top and bottom of each line/switch) and the bundle of wires in stove/oven box, testing continuity on each one. This will identify exactly where each wire DOES go... unfortunately, then you must determine where it SHOULD go (and sounds to me like those answers will be quite different) Be sure to get a VALID ground, since the stove is used near water. On mobile homes, this means hammering a long rebar or (specific, commercial copper grd rod) into the soil.
Posted on Dec 14, 2007
Anonymous
SOURCE: Light comes on, but iron will not heat up
I have the same problem with my black and decker iron. I will not buy orrecommend this iron to anyone.
Posted on Aug 09, 2008
muttandjeff
Allen Neal
  • 359 Answers
SOURCE: Electric outlet does not work
LETS START HERE , MOST OF THE GFCI BREAKERS WILL SOMETIMES RUN THROUGH THE BATH ROOM OUTLETS AND THEN OUTSIDE IF YOU HAVE A GFCI IN THE BATH OR LAUNDRY OR BASEMENT OR GARAGE MAKE SURE NONE OF THE RESET BUTTONS ARE IN THE TRIP POSITION THE NEC CODE CALLS FOR ALL OF THE LISTED PLACES AS WELL AS CRAWL SPACES AND NEXT TO AC/HEATPUMP TO BE ALL GFCI AND TO SAVE MONEY AND WIRE MOST OF THESE ARE DAISEY CHAINED TOGETHER TO SAVE MONEY SO THEY PUT ONE CLOSE TO THE BREAKER PANEL AND FEED THE REST OFF IT IT WILL BE A GOOD CK I HAVE HAD MANY CALLS FOR THIS THROUGH THE YEARS
Posted on Jan 10, 2009
Stahc63
oliso iron turns on when plugged in green light flashes but iron will not heat up
Posted on Apr 11, 2009
reddyanantha
anantha reddy
  • 205 Answers
SOURCE: My iron is not heating. Yes, it is plugged in a
hello mam
please change the thermostat of the iron and also check the heating element.
Posted on Oct 02, 2009
I have a Instant Heat 1 ½" Curling Iron by conair and it won't curl my hair. I've never use a curling iron this big? Any ideas?
Try putting styling gel or hairspray that is heat resistant in your hair first before curling it. but make sure products are for heat and styling first so it wont burn your hair! I have very fine hair that is straight as an arrow, and very hard to curl so before i use any curlers or curling irons, i put styling gel or mousse in it first then once I brush it out spray it again to hold the style
Mar 29, 2017 | Conair Health & Beauty
How to get Braun curling iron to heat?
Delilah, if it is a new curling iron and you plug it into a known good working outlet and does not heat up, it is defective. Return it to store for replacement or refund. If it is older and out of warranty, it is probably burnt out limit switch or may need rewired with new plug and cord(probably not cost effective, unless you can test and change)
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to fix broken curling iron Hot Tools repair
5 Troubleshooting Tips for Curling Irons
Hair Curler Repair How to Repair Small Appliances Fix It Club
The Beginner Guide to Repairing Curling Wand At Home
Aug 21, 2016 | Braun Irons
How can i gett my hair curly with no heat?
You can use curlers for that and manually curls your hair.
Nov 14, 2014 | Health & Beauty
Home electrical
Hi Sammy,
It sounds like there is a direct short on the circuit. Before going any further, check other outlets on this circuit and make sure they do not have anything plugged in that is not expected and does not work. Check OUTSIDE your home, basement, garage, etc. as these locations require GFI protection - and may be fed from the bathroom outlet. After removing devices that are plugged into the circuit, attempt a reset of the breaker once more.
It is not likely that the circuit breaker has failed (but is a possibility). The outlet in the bathroom is probably a GFI type. You can determine this if it has "Test" and "Reset" buttons on it. You should be able to press the Reset button in fully even with power off. After resetting, you can attempt the resetting the circuit breaker as you have described above. If it stays on, try pressing the "Test" button on the outlet. Doing so should trip power to the outlet (and causing the "Reset" button to pop out) but leave the circuit breaker "On". If the breaker also trips, the GFI outlet is suspect and might need to be replaced.
At this point, a qualified electrician should be consulted to locate and clear the wiring fault.
Apr 24, 2013 | Hammering
What types of hair irons are there?
The main types of hair irons are;
Curling irons - they create a curl or wave in the hair
Straightening irons - flatten or straighten the hair
Crimping irons - create a look similar to crimps left after braids are removed.
Jan 10, 2013 | Health & Beauty
Can i stem my hair after i week of relaxer?
yes u can , but i dont know what u mean by steam !!!!!!
from exsperiance u can curl or flat iron or wash and sit under the dryer
but i dont know what u mean by steam.
Nov 30, 2012 | Organic Root Stimulator Organic root...
We just moved into a new house, and whenever I use
It sounds like it could be one of the following issues:
1. Bad wiring to the bathroom receptacle - this should be a GFCI outlet.
2. There is an overload somewhere on the same circuit - try the dryer with nothing else turned on.
3. The hair dryer may be bad or have a bad cord, plug, etc. Hair dryers can also become plugged (the air inlet screen) and overheat.
4. There could be loose or other bad wiring somewhere in the circuit.
If you are not familiar with working with electricity, it would be best to call a qualified electrician. They are the pros and can correct the problem.
May 20, 2010 | Kitchen Appliances - Others
Clothing Logo
309 people viewed this question
Top Clothing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Jim Pattison
Are you a Clothing Expert? Answer questions, earn points and help others
