Hi Check the relays, You have one for the right side lights and one for the left side. I had to replace one that had broke on the inside,
Hope this helps some one.
The circuit goes from the brake light switch thru the turn signal switch and uses the same bulbs as the rear turn signals. I would check for power in and out of that switch next.
the switch controls both front and rear signal lights.the wires just T off in the harness to go both ways.you don`t say but are the rear bulbs ok.there is 2 filaments in the bulbs one for tail lights and one for signals/brake lights.so the brake lights work if so then the bulbs are good.if not then the bulbs may be the problem.it could also be a wire feed/ground problem that you will have to trace from the sockets back through the system with a test light checking for power and ground.
It sounds like you have a bad mastercylinder cause when you panic brake it doesn't have time to bleed through the valve in the cylinder but under normal braking your foot is on pedal longer in turn giving the fluid time to bypass the valve in the mastercylinder in turn the pedal going to the floor.
Sounds like a short in your wiring. Have you checked the bulbs and you could have bought a bad brake light switch. Try having somone step on the brake lights and use a test light to see if your getting current back there
Straight forward job. Remove wheels, remove 2 caliper bolts per wheel, check bolts,and bushings for wear/corrosion and lubricate, remove calipers, remove brake pads, push caliper pistons into calipers, replace anti-rattle clips, put new pads in, put caliper and bolts in, put wheels on. Start truck and press brake pedal several times to take up slack and you're done.
