Hotpoint HSS25GFP Side by Side Refrigerator Logo
Posted on Jun 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ice maker not dumping ice
We just moved, prior to moving had no problems with the icemaker since we've moved it's not working. Water is getting into it but doesn't dump it once it's ice.
Anonymous
Level 2:
Novelist:
  • Expert 103 Answers
  • Posted on Jun 08, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
103
Questions
0
Helped
54239
Points
310
Hi: Not knowing how long it's been hooked up... Ice production can take as long as 72 hrs to start. Usually 24 to 48 hrs. The freezer also has to be stable at 0 degrees F to start producing ice. The tray mab be full but it wont dump untill 0 degrees F. Another thing is it's human nature to keep opening the freezer to see if Ice has been made. This justs dumps the cold air out and will slow the ice production. Just because your food is frozen dosn't mean it is at 0 degrees F. Ice cream should be rock hard. Try setting your freezer colder and allow 24 hrs for it to stabilize. This is the best try and it usually works, before calling a tech. I hope this helps, Jeff
2helpful
My icemaker stop working but the water dispenser still working I check both water lines from the filter its ok but can't check the freezer line by icemaker. turly don't know why the water will not flow...
If there is no ice in the ice mold of the ice maker, you can pour enough water in to make cubes, wait an hour or so for the icemaker to cycle.( freeze and dump the ice). If it does, then your water valve on the back of the refrigerator that the main water line hooks up to is bad. Replace it. The valve has two sides to it. An ice maker side and a water resevoir side. One side can be bad allowing the other to work.
If the ice maker does not cycle and dump the cubes then you probably have an ice maker problem.
Ice maker quit workingon kitchenaid side by side bowfront
check to make sure yr getting water to inside of ice maker if you are then replace the icemaker you can order them from marcone or allbrands appliance
After 2yrs of not using the icemaker, moved
Good day,
Pour water from small paper cup until it near fills the well of the ice maker. With the lever down, close freezer door and wait 2 to 3 hours. If it dumps then the ice maker should be good, if not, replace ice maker.
If dumps O.K. then the dual water valve is bad, and needs replaced.
You should check the fill tube that runs from the back of the machine to see if it is blocked with ice. (requires removing ice maker) but even so, if it is iced, you'll need to clear, but the water valve in the back rear of the machine is leaking and still needs replaced.
Thanks for using FixYa
4helpful
Ice machine does not make ice
No guide that I know of .
Open the freezer door and see if the laser light on the right side , flashes twice , then pause , repeatedly . Close the flap on the left side , and the laser should stop flashing . If this is what occures , then the optics ( cut off of the icemaker ) are ok . If you open the freezer and no laser on the right , check the position of the "rake" inside the icemaker . Close the freezer door for about 1 min , and then recheck the position of the rake . If it hasn't moved , then the icemaker is bad .
If the light flashes 2 times then pauses , pour about 2/3 cup of water into the icemaker , and check later , to see if the ice maker has dumped the cubes . If did not dump , replace the icemaker . If did dump , and did not fill with water , then the water valve behind the refrig is bad . Also check the black fill tube above the ice maker fill cup , to see if it is iced up , keeping the water from going into the fill cup . If it is frozen , then replace the water valve , due to seeping ( not closing completely ) , causing the slight drip , to freeze inside the tube .
This is the only guide I know of and it's called an experience guide .
2answers
GE adora side by side refrigerator DTL181C5RRBS
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Whirlpool IceMagic Plus not working.
Pour about 2/3 cup of water into the ice maker . If it dumps the ice but doesn't refill , replace the ice maker . If it doesn't dump , and the cubes stay in the ice maker , replace the ice maker .
The switch on the icemaker for normal , runs the icemaker normaly . In the ice plus , a small fan comes on , blowing the inside air , over the ice maker mold , to help it freeze faster .
2answers
Why is the ice maker not droping ice / Mod. ET1FTTXKQ00 / Type C21TFA01 Whirlpool 08-01
Take a 4 inch piece of 14 gauge insulated wire and strip 1 inch of insulation off each end. Bend the wire into a U shape.Remove the plastic cover from the front of the icemaker. Insert the bare ends into the terminals marked T and H on the face of the icemaker. The wheel should move and dispense the ice into the bucket. If it does not move and drop the ice replace the icemaker.
1helpful
2answers
Ice maker stop making ice
I had the exact same problem after looking at the ice maker I saw that there was a test button I pressed the button and it started working again
try that!!
LFX25960ST Ice maker problem
As long as switch on icemaker is on then your i/m died. It needs to be replaced. I can get LG parts if you need one. Please leave feedback. Thanks
2answers
Kenmore Bottom Freezer 596.71103101 Ice maker not working right
Did you find icemaker solution? I have the same unit. Ice maker worked perfect. Then moved to new house, icemaker stopped working. One day it worked (old house), the next it stopped (new house)!
Top Hotpoint Refrigerators Experts
ZJ Limited
ZJ Limited
Jose Ramirez
Sean Wright
Sean Wright
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
