SOURCE: kitchen aid superba side by side refrigerator
I slid our unit out tonight and took off the cardboard cover and vacuumed the back area out. If you do this unplug the unit. I didn't see the spinning fan blades next to the compressor until after the vacuum nozzle touched them.
I then took off the front cover down by the water filter. We have 2 long hair cats. 5 years of fur had collected and was preventing air from circulating out the front of the unit. I vacuumed out the fur. I then took a short flexible rubber tube and hooked it to the vacuum and got as much fur and dust off the coils underneath the fridge box.
Once I had everything put back together and plugged back in the frame cooled down and I think we are OK. My guess is the hot air could not escape so it was gradually heating up the frame.
Good luck.
SOURCE: kitchen aid side by side 2003 KSC... freezer not freezing
sounds to me like a bad compressor....might want to have that looked at by a pro.
SOURCE: Kitchen Aid Refer: KSSC42FMS01: The freezer, doesn't go below 32
How long have you had this refrigerator and is this the first time this has happened? Your refrigerator has a control board and I believe the board is causing the refrigerator not to defrost every 8 hours. Let me know these questions and I will help you resolve this. Thanks, Sea Breeze
SOURCE: Kitchen Aid refrigerator KSRS251 - not
Sir Good Afternoon..
the problem of your refrigerator is lack of Freun gas
Bring it for Refrigerators Specialist because they are the to put that Freun gas..thanks
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
