SOURCE: HP OFFICEJET 4215 cartridge error
Try this while standing on one leg.
1. OPen ink caridge lid.
2. Remove the affected cartridge.
3. Close lid
4. Try to print. This will fail, but that is ok.
5. Open the ink cartridge door again.
6. Remove the other cartridge.
7. Unplug the unit.
NOTE FOR THE NEXT STEP
This can be risky and I asume no responsibility for pressng too ******* the contact points, havng too much alcohol, using the wrong kind of alcohol, or not using alcohol or other such problems that can occur.
8. Using ONLY alcholo lightly brushthe contact points
9. Lightly clean the cartridge cotact points.
10. Plug in the unit
11. Install the cartridges.
12. Go through the alignment process.
13. Switch to the other leg, those with one leg only are exempt.
14. You just might be ready to print again.
I know this sounds crazy but this just worked for me.
Callan
SOURCE: HP Officejet 4315v Error Code 344*
1. issue may be with telephone line conditions, try sending a fax at a different time 2. Disable Error Correction Mode 3. reduce thefax speed 4. try a fax test to hp at 1888 473 2963
SOURCE: error code i hp 4255 officejet printer
have problem in my printer hp officejet 4255 oll-in-one it give message ERROR : 0XF0aF8005 pleas help me I can repair the priter if u can diagnose the error code
SOURCE: ERROR :0xf0af8005
Solution one: Reset the product
Solution two: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
SOURCE: I can not install my HP Printers Officejet-- gives fatal error
This issue requires some serious trouble shooting and solutions cannot be posted as they are too long.
If you want further support you can avail free technical support on http://tinyurl.com/m7ghqz
