Ariens 34 In. Zoom Series Riding Mower Logo
Posted on Jun 07, 2009
Ariens ezr 1742 will not move. everything works fine except it will not go forward or reverse.
Anonymous
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Jul 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
12034
Points
42
There is one common problen that causes this. Infront of the rear wheels there are two housings for the indepentent hydrostatic transmissions. There is one gold colored shaft with a ninety degree angle on it sticking out from EACH of the housings on the top front. Again these are on both sides and they each need to be pushed downward so that the rods can then be pushed backward into the transmissions to inguage them so both of the wheels are powered. Give this a try.
  • Anonymous Jul 09, 2010
    If that does not help there are belts that drive the pumps to work the transmissions make sure the belts are tight and running the pumps if everything is working and transmissions are still unresponsive the pumps may need to be replaced.
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Dec 03, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3971
Points
9
Put a drive belt on it.
Ariens 1742- blades will only engage while moving. Once you bring arms to neutral the blades stop.
The problem likely is with the SEAT/PTO RELAY not remaining energize. Look for open or disconnected wire (PURPLE) from the relay towards the ignition switch.
See wiring diagram;
https://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/ariens/zero-turn-lawn-mowers/ezr/915308-000101-ezr-1742-17hp-b-s-42-deck/wiring-diagram
2answers
When turning on pto blows the fuse
Look over the entire wiring harness wherever it may be touching metal as it probably is chaffed, simply tape and zip tie it away from the ground source.
My 1999 Ariens EZR 1742 will not move. Cranks and
if both belts are present are they both moving? Could be tensioner froze up and it is not applying tension. mine had and i had to remove and free it up.
Looking for manual Arien EZR 1742
Go here:
http://www.ariens.com/corporate/pages/partsradar.aspx
Hope this helps
Top Ariens Garden Experts
john h
Mike Cairns
Mike Cairns
CJ Rock
CJ Rock
Are you an Ariens Garden Expert? Answer questions, earn points and help others
