Can i save music to my micro sd card and put it on my phone?
Why cant i get my micro sd to show on my phone
Hi im trying to get music in micro sd for my en-v2 on verizon and i cant play the music when i add them to the card can someone tell me how i can get it to work?
My sd card displays that the music is on it. but when i put it in my phone it doesn't act as if any music is on it. the card is brand new.
If u are able to save music in your mobile, if facing problem in u micro sd, there is problem in your memory card, u r memory card is corrupted,so fomat u r memory card ,than try, but it will lose u r data, so take the backup first
I had the hardest time getting my new 16gb micro sd card to work in my new env3 with mp3s. I called a very helpful verizon technical support person. You must format the card using the phone and may need to do it repeatedly. Mine kept saying it was corrupted. Finally I used my wife's env3 and had to reformat it in her phone twice. With the card in the pc the folders showed up. Finally, I was able to move the wma and mp3 files to the music folder. Some have pictures, some don't. Next I will try video files and put them in my flix folder. I suspect they must have the required video size and audio output.
Ok, finally i got my card to show up on my computer, but when i try to add songs to the my music folder, it says the disk is write protected. helppp please
I sync music on to my phone and when i open my phone i cannot find it i then look on my computer and it says it is there but my phone says it is not what do i do HELP !!
I downloaded the driver for Vista..only the USB driver and not the VCAST-Rhapsody thing. THen, when I plugged in the Chocolate 3, I made sure that I looked at it's screen and told it to sync music while I had Windows Media Player 11 open. It then recognized it as a device and I was able to sync WMA and MP3 to it just as I would any regular windows compatible player.. not sure about WMA protected though.
Right click the song then properties and uncheck the archive then ok
Mp3 works fine. But you have to have all of the files in the My_Music folder only, sub-directories are supported.
Here is how I put music from my computer onto my LG Chocolate:
Put the Micro SD card into the phone, so that it creates various folders, such as "my music", "my sounds" etc. Using a Memory Card Reader, put MP3 files onto the Micro SD, in the "my music" folder. That's it!
If you use MP3 format on the disk it should work, format the SD disk 1st and then upload the MP3. I wouldn't use the wav files if that's the format your using. Give that a try
You have to convert the files to WMV format and then put them on the card for it to work.
SOURCE: saving music on my micro sd..
well assuming you loaded music on your sd card:
to find it, just go to mystuff....
menu, mystuff, center button, it should load the mini sd right there. then all you have to do is click over right and file explore the mini sd. you should put music in the music file.
another option on the phone.....
go to att music
menu, upper left icon, center button, music player, it should find all files.
let me know how i can help some more
try and reformat the card then try again......make sure the files are .jpg,.jpeg,.gif etc and the music is .mp3
SOURCE: how do i put music on my motorola ve240?
Okay, try this. I had the same problem, but I finally found the solution. If you plug up your phone into the computer, and it doesn't pop up with the Hard Drive and Removable Devices, this is what you must do. {{{Settings > USB > Mass Storage}}} Then, plug it up. It should pop up then. Then you can drag and drop music files from your computer to the phone. It's rather simple once you find out what to do.Hope I was able to help guys!
I have an adapter for my micro sd card for my samsung phone but when i put it in the computer and copy files from windows media player and put the card in my phone it shows up as incorrect data format...how do i put the m usic in on the right format?
i do not know how to save the music to my SD card?
i already saved music on my micro sd but once i inserted in my phone nothing happens, i already formated the card.
i put my music on my jump drive that the micro sd card fits into and when I put the sd card in my phone it says that connection failed.
haave formated chip with phone, put chip in adaptor and adaptor to pc. How do I get Microsoft Music player to put the music in the my_music folder?
i cant upload music to my micro sd chip
can i save music on my microsd card and then save it on to my chocolate phone
when loading mp3 gives error that the disc is write protected.what do i do?
i cant find the music folder unless its in my phone, it doesnt show up through the computer.
,micro sd card and I have a mac laptop
i do not know how to get the music from the computer to my phone using the micro sd card
i synced music onto the sd card but i cant find it on the phone
i saved music on my micro sd card but i cant get it on my phone
i got the music onto the micro sd card but when i format it to my fone and go into my music it tells me that there is none
my lg chocolate won't recognize my music files on my microsd card that i filled up on my mac. any solutions?
I don't kno how to get music on my micro SD disk for my LG Versa
there is music on my card but my phone wont recognize its there
how can i put song from my computer to my micro sd
I'm trying to load songs onto my mini SD card for my MP3 player, but I have no idea how! HELP!
i put the sd card in my lg vu and then connected the usb cable like the instructions said, but it still says insert memory card for music sync or mass storage... help!!!!
