SOURCE: drivers for hp proliant dl140 g2 ..network drivers
Just go through the following link.Just select your operating system.and download the driver you want.
CLICK HERE
Thanks
SOURCE: why I can't boot from DVD
You must have a bootable files in a DVD where system files are usefull as bootup system.
SOURCE: Hi, how to switch off HP
The fans are essential to the cooling of the processors and everything else in there, if they are running fast then usually that means your processor is overworked. I'd go for a fresh operating system if you can.
The fans should come on really fast when its first turned on, then slow down after a few minutes.
SOURCE: HP ML 110 G2 will not boot from CD. How do I fix
1) boot PC using DEL key to access BIOS
2) chanche boot devices priority
SOURCE: how to boot from CD hp proliant ML 110 G6 sever
Check BIOS for boot sequence. CD-ROM / DVD should be 1st.
