I Have x3 GE Store Safe DVRs .. The problem is that they are keep restarting again and again immediately after boot up. I have changed there Power Supplies but it did not work.. I replaced the hardrive whcih makes its stable but when I put it on recording .. the problem again started.. Any Solution??
1. Restart the Acer Aspire netbook by pressing the "power"
button on the netbook's keyboard or by pressing the "CTRL," "ALT" and "DEL"
keys at the same time.
2. During startup, hold down the "F8" function key
immediately when you see the "Acer" splash screen and the option for entering
"Setup."
3. Keep pressing the "F8" key until the "Advanced Boot
Options" menu appears.
If you receive a "keyboard error," restart the Acer Aspire
and repeat step 2.
4. Use the arrow keys to navigate to the "Safe Mode"
selection on the "Advanced Boot Options" menu.
The arrow keys are located on the right-hand side of the
Acer Aspire keyboard.
5. Press the "Enter" key to execute the "Safe Mode"
selection.
The Windows operating system will now start in "Safe Mode"
and you can perform a system restore or make needed changes to get your Acer
Aspire to boot normally again.
If you have having boot problems and the system keepsrestarting, then turn off the computer, then hit the power button andimmediately start hitting the F8 key repeatedly until you see SAFE MODE. Scrolldown past Safe Mode and you will see an option to DISABLE AUTOMATIC RESTART.Take the Disable Automatic Restart option. This should allow you to see an error message if one is being presented.
If you have having boot problems and the systemkeeps restarting, then turn off the computer, then hit the power button andimmediately start hitting the F8 key repeatedly until you see SAFE MODE. Scrolldown past Safe Mode and you will see an option to DISABLE AUTOMATIC RESTART.Take the Disable Automatic Restart option.
Automatic Restart? Are you trying to Start Automatic Restart or Stop Automatic Restart?
If you have having boot problems and the system keeps restarting, then turn off the computer, then hit the power button and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Scroll down past Safe Mode and you will see an option to DISABLE AUTOMATIC RESTART. Take the Disable Automatic Restart option.
Restart the Acer Aspire netbook by pressing the "power" button on the netbook's keyboard or by pressing the "CTRL," "ALT" and "DEL" keys at the same time.
During startup, hold down the "F8" function key immediately when you see the "Acer" splash screen and the option for entering "Setup."
Keep pressing the "F8" key until the "Advanced Boot Options" menu appears. If you receive a "keyboard error," restart the Acer Aspire and repeat step 2.
Use the arrow keys to navigate to the "Safe Mode" selection on the "Advanced Boot Options" menu. The arrow keys are located on the right-hand side of the Acer Aspire keyboard.
5
Press the "Enter" key to execute the "Safe Mode" selection. The Windows operating system will now start in "Safe Mode" and you can perform a system restore or make needed changes to get your Acer Aspire to boot normally again.
Read more: How to Boot Up Acer Aspire in Safe Mode ' eHow.com http://www.ehow.com/how_5802430_boot-acer-aspire-safe-mode.html#ixzz1dtOxfxaD
Try tapping F8 while booting and go to boot with "last know good configuration" if that doesn't work hit f8 again while booting and go to "safe mode" and do a system restore :) hope this helps thanks
Here are some steps to use MSCONFIG to force your computer into SAFE MODE
Click on Start and then Run.
In the text box in the Run window, type msconfig and click OK. This will open the System Configuration Utility program.
Note: Do not make changes in the System Configuration Utility
other than those outlined here to avoid causing serious system issues.
This utility controls a number of startup activities other than those
involved with Safe Mode.
Click on the BOOT.INI tab located at the top of the System Configuration Utility window.
Check the checkbox next to /SAFEBOOT and click OK.
You will then be prompted to either Restart, which will restart the PC immediately, or Exit Without Restart, which will close the window and allow you to restart the PC manually.
After the restart, the PC will automatically boot into Windows XP Safe Mode.
Note: Windows XP will continue to boot into Safe Mode until the System Configuration Utility is configured to again boot normally.
When your work in Safe Mode is complete, click on Start and then Run. Type msconfig in the text box and click OK.
This will again open the System Configuration Utility program.
Choose the Normal Startup radio button and click OK.
After the restart, the PC will boot into Windows XP normally and will continue to do so.
To boot to safe mode: Restart
the computer. As soon as the BIOS has finished loading, keep tapping on F8 key on your
keyboard. When the Windows Options menu appears select the "Safe
mode" then press Enter.
Once
you managed to boot to Safe mode, change the computer startup and
recovery settings by right-clicking "My Computer" then select
Properties. Select Advanced tab. Under Startup and Recovery, click
Settings. Uncheck the box for "Automatically restart" under System
Failure.
Reboot again normally, see if it will reboot again by
itself. If you managed to make the system boot normally, proceed to
Events Viewer to find out what is the caused.
If the system
failed to boot normally after doing the above, you might want to boot
the system to "Last known good configuration"
