Intuit QuickBooks Pro 2011 (License Only) Logo
CLARENCE S. BONDO Posted on Feb 10, 2014
Hp laser jet m5035 mfp displayig 49.4c18 error code how
Amos Dennis
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on May 01, 2014
Amos Dennis
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
2622
Points
I'm having problem with this error code 49.4 c18 on my hp laserjet m 5035mfp printer.Can any body he in solving this problem ?
  • Amos Dennis
    Amos Dennis May 01, 2014
    Can anybody help in solving this problem.
HP LaserJet Pro MFP M130fw. Error code 58.04 Laser jet pro mfp m130fw
Question edited for clarity and toss in a load of CAPS.
Question moved from 'Jet Office Equipment' category.
It's not good!
HP Color LaserJet Pro MFP M477
Printcopy.info https://printcopy.info > brand=HP > code=58
Code: 58.04; Display: 58.XX Error, Turn off then on; Description: The product has experienced an error with the low voltage power supply.
Missing: M130fw. ‎' Show results with: M130fw.
58.04 printer display error on powerup
HP Support Community https://h30434.www3.hp.com > td-p
Aug 2, 2018 - THE ERROR CODE PROBLEM OF MOTOR POWERSUPPLY BOARD (SMALL DAUGHTER BOARD TOP OF THE SCANNER UNIT), Transistor no of 905,903 like ..before you change check motor ...
My printer is displaying, "58.04 Error power outage detected...
Jun 28, 2022
Laserjet Pro 400 MFP 451dn error message 58.04
Aug 5, 2013
My laser jet MFP M477fdw printer is showing 58.04 error cont...
Sep 22, 2021
HP M451 Error 58.04 - HP Support Community - 5830295
Nov 1, 2016
More results from h30434.www3.hp.com Missing: M130fw. ‎' Show results with: M130fw.
Error Codes > HP > LaserJet Pro MFP M130 > Code 58.XX
Code: 58.XX; Description: The product has experienced an error with the low voltage power supply. • 58.04 = Low voltage power supply malfunction; Remedy: 1.
Hp laserjet m5035 mfp error 49 ff04
I think you are since the dc controller only controls paper movement and nothing else. A 49 error is a firmware error and has many causes from applications, network and just defective formatter. If the errors occurs with the printer not connected to anything, then the formatter would be the logical issue if the firmware has been updated. Keep in mind having a jet direct card in the slot can cause the error, so the only true way to test is with everything removed with the exception of firmware, memory and power. Also keep in mind that if the 4250/4350 series power is derived from the lvps and not the dc controller. Also with this model the embedded jet direct card is known to occasionally have issues. When you upgrade the firmware for the formatter it also upgrades the firmware on the embedded nic card. Again the only true way to test would be to disable the embedded nic card on powerup.
Read more... HP Support document HP Support Center and HP Printer Support
HP Color Laserjet M5035 get`s error 30.01.34
First, this model is not color laserjet, only black.
HP LaserJet M5035 MFP
30.1.34 Cable error or loss of communication with the formatter.
1. Turn the device off and then turn the device on.
2. Make sure that the ribbon cable between the scanner control board and the formatter is not damaged and is correctly seated.
3. Make sure that the hard disk drive on the formatter is connected correctly and that the hard disk is functioning correctly.
4. If the message persists, replace the scanner control board or replace the formatter.
2helpful
Error code 52.00
52.00 = laser/scanner error
1. Turn the device off, and then turn the device on.
2. Reseat the connectors between the laser/scanner and the dc controller PCA (J801 and J321).
3. Replace the laser/scanner assembly.
4. Replace the dc controller PCA.
1helpful
Laser error
You may have to replace the laser/scanner assembly or the DC Controller
Sorry
1helpful
My printer name is HP M5035 MFP LASERJET serial number cncxbo4735.it can't scan or photo copy error code 30.1.19
fixed the problem by removing the scanner cover and sprayed compress air on the scanner light bulb and cleaned it out.Put back together
Top Intuit Computers & Internet Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
