Health & Beauty Logo
Gene Pitts Posted on Feb 10, 2014
Braun station. cleaning cycle stopped working.
Model#B9 5648(on base).Model#5643 Activator Series#549(on razor).Charger-Good LED on.Razor Ops-Good.Cleaning Ops-No.Fluid level(new cartridge)-no LED.Disassembled Base-visual OK.Need schematic of Base PCbds & wiring.Pump motor test-OK(by itself).New Base not option.($).All suggestions welcome. Thank You.
3 Related Answers
Anonymous
  • Posted on Aug 09, 2008
SOURCE: cleaning base
I have been shaving with electric razors for 48 years, and the Braun 8595 is by far the best one yet.
I have had the problem of the refusal of the cleaning station to recognize the level of fluid in the cartridge, three times over the last couple of years. It seems to relate to a build up of shavings in the unit. To get it working again I inverted the unit, and carefully flushed water via a small tube, back through the 1cm diameter hole in the underside of the open base. Of course, the unit must then be thoroughly dried before use, or the sparks may fly. Does anyone know how to dismantle the unit for a safer and more thorough clean?
caroldon
  • 17130 Answers
  • Posted on Sep 28, 2010
SOURCE: I have a Braun 760 razor. The two electric
Useaa good emery paper to clean the surface of the contact, use a good contact oil to rub off the rust or dirt in the section. now repeat till it shine, do the same to the other end , Now since there is alwyas some moisture present the pins must be cleaned out after very use.
brector3
shaveroutlet.com
  • 1652 Answers
  • Posted on Oct 09, 2010
SOURCE: Braun 8585 shaver, charges fine,
The problem is the base, not the shaver. Most likely, the circuit board inside the base has gotten wet and is damaged. If this is the case, it will need to be replaced. You will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-360-complete-clean-charge-base-p-116.html
1helpful
Braun series 3 390cc, charging base will not clean razor.
Most likely, the pump has stopped working. This is not repairable since part for the cleaning station are not available.
A replacement can be found at shaveroutlet.com
Braun Clean Charge Base 5783 Fits Types 5772 5774
1helpful
2answers
How to fix a Braun series 7 razor that will not charge in cleaning stand
I have a Braun 7 series that I use occasionally. The last time I tried to charge was unsuccessful. After several days on the charger still would not charge, I discovered the RESET button right under the Braun name. The charger cable has to be unplugged, then press reset with a paper clip and now works like a charm. Note: reset will not work if charger cable is plugged in.
3helpful
Braun series 7 cleaning station has red lights even after I replaced the cleaning solution
When the razor is not regularly cleaned in the cleaning station and the hygiene indicator goes low, the cleaning station may lose its ability to sense the fluid level. I almost sent the cleaning station in for repair (mine is out of warranty) but was able to clear the faulty condition by resetting the razor's cutter replacement (holding the small recessed reset button below "Braun" logo on the razor) and unplugging/replugging the station then attempting a cleaning until it performed one completely successful cleaning cycle. After that the fluid level showed full. I also heard that the drain hole in the "cup" where the razor sits can get clogged - not sure what happens then but you want to keep that clean.
Update 2/2018: If you mix your own formula as others note, it is important to include some tap water for electrical conductivity for the fluid sensor to work.
Braun 8995 - YELLOW LIGHT STAYS ON!
I experienced the same symptoms on my 8995; solid yellow light (even though the cartridge was full), cleaning failed (red light on) after pressing either start button. After many failed attempts to clean the razor, unplugging the station and pushing start button, I decided to clean the razor under running water. I rinsed the razor under water and then turned it on allowing it to run in a pool of water (like it would in the station). After water cleaning, I returned the razor to the station, pressed the start button and it worked! Was able to do both the quick clean and auto clean.
When razor is plugged in for charging the whole razor and cord get really hot! What is going on? It is a 4700 Series razor but it says For use only with Braun Series 549 class 2 power units. Do I need to...
After reviewing your Problem , My think says , its a Machine Problem... or may be its a Heat Problem , the Reason of Heating is that , the blade of machine is not installed Correctly , so Blur your Machine , clean it all ,then it will okey.
3helpful
Looking to replace the head of a Braun 549 series. Can't find a replacement. Was told the 7000 series would fit and they aren't the same. Please help???
http://www.amazon.com/Braun-70S-Cassette-Replacement-9000/dp/B001VEK1HQ/ref=sr_1_1?ie=UTF8&qid=1305831009&sr=8-1 thats the exact replacement head its doesnt go by series it goes by the 4 digit number on the side, which on the 549 is a 9585,braun has made it confusing as hell to get the right part, its a series 7 razor but has series 549 on it but to get replacement parts you need to look for 9585. that is the correct part for your razor though.
Oct 22, 2010 • Vacuums
2answers
Braun 8595 clean and renew will not charge or clean my razor, in fact it just ignores my razor
it sounds like your clean and renew base will need to be replaced. you will find a replacement at shaveroutlet.com
8985 360 conplete. I got a new charger & cleaner base. Unit chargers and full lights comes on. Cleaning cycle lights does not work or clean. This is third new base i tried. I think truble is razer. I...
the razor is warranted for 2 years if you want to contact Braun for replacement. You can try to tap the razor with the palm of your hand after taking off the shaver top and blades. Sometimes this will help dislodge anything that is keeping the shaver from making good contact inside razor.
Just don't beat it against anything hard.
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
ZJ Limited
ZJ Limited
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
