Kitchen aide khws02rmt0 washer
random issues with bad solder joints on the boards ,
open the top of unit , reseat all the connectors on the control unit.
start washer ,
, push up gently on the center black wired connectors . system should start and run fine as long as you hold it up. normal issue is that the solder connections to the relays need to be resoldered due to crack around the leads.causing random issues
german manufacture board
