Question about LG WM2688H Front Load Washer
Hanning dp025-208 drain pump
Hi I need a replacement for a hanning dp025-208 220v drain pump
Dishwasher doesn't drain.
sounds like the pump is locked up and needs replaced. try the internet appliance parts
Apr 07, 2014 | Frigidaire 18" Built-In Dishwasher
Hi our Bosch exxcel washing machine has stopped spinning and doesn't reach the end of its cycle most of the time. If it does the washing is still soaking and needs a new rinse and spin cycle after....
Hi gillsteer,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Bosch Washing Machines
Washer will not drain water frigidaire
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Please revert for any further assistance.
Hope this helps...
Daniel
Feb 17, 2011 | Washing Machines
My washer will not drain the water is there anyway to manually drain it
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. If it still doesn't work then you would need to replace the drain pump. Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Washing Machines
Will not drain before spin
Hi
If the washer is not draining then it is due to a clogged drain pump or a drain filter or a kinked drain hose. To resolve the issue you’ll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn’t work then you’ll need to check the connections of the drain pump, check the connections with a multimeter. If it still doesn’t work then you would need to replace the drain pump. Please revert for any further assistance.
Daniel
Aug 30, 2010 | Washing Machines
Wont drain
Hi
Daniel
Aug 28, 2010 | Whirlpool Washing Machines
Intel D865GLC Mother Board which wont save changes to BIOS
Hi Hans
Try to restore the bios to factory defaults.
then restart the Computer and then change your settings again and see if it works then
Apr 26, 2009 | Intel D865GLC Motherboard
Washing machine will not spin
HI mate , if your model is an LG 8013F . I had the same problem . evrything is control by the CPU and it cannot be repaired .
What i had done is to replaced the Control board completly and it works perfectly .
I have one unit extra if u are interested let me knw , i can sell it for $60 + PP
THanks
Hans
Nov 13, 2008 | Washing Machines
LG WM2688H Front Load Washer Logo
254 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
