Question about LG 50PX4DR 50 in. Plasma TV
Recording shows on dvr
Shows wont record on the built in dvr even thou I have set channel time and dates must be doing something wrong
Anonymous
SOURCE:
Anonymous
SOURCE: LG DBRH197
Read the timer record troubleshooting suggestions - timer record will only start is the unit is turned off!
Posted on Aug 02, 2007
Anonymous
SOURCE: LG RH177 Recording
once you have set timer record, you must then put machine in standby mode,once in standby mode you will have a little timer display in panel,should then come on when time to record
Posted on Oct 17, 2007
Anonymous
  • 21 Answers
SOURCE: LG HDTV large screen is blank but guide/list/pip shows up
Hi there, Im Kanth, i had the same problem, and i found a person in Mississauga, they fix all kind of problems in Plasma, they fixed my LG before a 7 months, its still running good, i came to know lots of ppls were having same problems, i sujest u to being the plasma to electronics @ Dixie and Britannia Mississauga, call them now 905 565 6595 or check there wesite for more info. http://dukeelectronic.com
Posted on Apr 22, 2008
tom walsh
  • 226 Answers
SOURCE: After recording a one hour episode, won't recognize the dvd.
Try inserting your DVD media into the PC and doing a 'quick format'. The LG is not seeing what it considers to be media that it can use. It is not seeing that you have inserted recordable media. Sometimes you can reformat the DVD or do a quick media erase, and the LG can then put on its blank "squares" that is uses for its menu selection. I think that it what it does when it 'initializes' a new media.
tom
Posted on Jan 10, 2009
Anonymous
SOURCE: LG RHT397H DVD Timer record problem
Sorry used wrong site have moved to LG DVD forum. Ta
Posted on Jan 18, 2009
Why dose recording in dvr goes on default date when light goes
Well, I'm trying to decipher this. Why does the recording in DVR revert to the default (date/time???) when the light goes off and comes back on.
I'm guessing you are trying to say time, not date, maybe day?
The DVR is trying to remember when a show comes on and record it, based on your settings. Usually shows come on at a specific time. DVRs usually update their scheduled recordings based on updated programming guide information. If you are constantly unplugging or causing your receiver to otherwise restart, most receivers will download an updated guide upon getting power back or restarting (DVRs themselves not having any idea how long they've been without power, download a new guide just in case after you unplugged them you moved to Arizona). During this time, the recording you set is showing the original time you set it up, because until the guide is downloaded, it has no idea that its wrong.
My best advice, even if I'm wrong about our language barrier here, stop unplugging your receiver. Leave it plugged in and powered at all times.
All times.
For ever.
Dec 18, 2016 | Televison & Video
I had a new dvr added to my TWC cable services,but installer did not totally explain how to record or find recordings after taping. Can anybody tell me how to remedy this problem?
http://www.timewarnercable.com/en/support/faqs/faqs-tv/on-screeng/iguide/how-do-i-record-a-show-using-m.html
How do I record a show using my DVR and i-Guide?
There are multiple ways to do this:
  1. Press the RECORD button on your remote control while watching a program to begin recording. An overlay will appear on your screen to let you know you have started recording.
  2. From the TV listings grid, highlight the show you want to record and press the Record button.
  3. From any program information screen, highlight the Record icon and press the OK/Select button on your remote to schedule a recording. Follow the on-screen prompts for additional recording options.
Manually schedule a recording for a specific time or channel:
  1. Press the MENU button on your remote control then select the DVR icon.
  2. Or, if available, press the My DVR button on your remote control.
  3. Select the start time, end time and day that you want to record.
  4. Press Confirm.
  5. In the channel list that appears, select the channel to record from.
  6. Select Record to confirm your settings or select Recording Options for additional options.
and:
Video:
How to video DVR
Jul 12, 2016 | Televison & Video
Bunker hill 67139 dvr hard drive wrong year 2058
The issue may be is that you have a DVD in your dvr , that still shoes that date and time. Just a possibility, not sure,. try to see if you can take DVD out of dvr, and use a new one. I happened to me but, the case was a vcr,and I had a recorded video tape which while playing , was showing a blue screen, with "no data received" which actually it was when no data vcr was receiving from cable at the time it was recording . If the problem still is not solved then there is issue with some circuits, and processors. Also you may want to check if Bunker Hill has any customer support, to check with them.
May 18, 2014 | Televison & Video
Screen wont show cameras or record
Are you pressing menu button on the monitor or the DVR?
Your problem may not be the cameras, but between the DVR and the monitor. Found this on page Eng-19 of the user manual which I found on Samsung.com
This monitor was set to password lock when you purchase a new set. Therefore, you must first enter a 4 digit password to activate the On Screen Display... the default password is 4321. Not sure if that helps.
Dec 17, 2013 | Samsung SMT-190DN 8-Channel Security...
Panasonic DMR-ES25 Trouble setting up to record TV shows
The DMR-ES25 does not have an ATSC tuner; it has an NTSC tuner. See page 54 (Specifications) of the manual at the bottom of the left column (television system). You need to add digital to analog (ATSC to NTSC) OTA converter box between the antenna and the DVD recorder. Next, you will set the converter box to the channel you wish to record and set the DVD recorder to record on a composite input (Line in) or channel 3/4 depending on how you set up the converter box.
The only remaining analog broadcasts are a few low-power stations. Unless you live close to one of these transmitters, your DMR-ES25 will not be able to tune in any channels. Make sure that you find a converter box with composite and/or RF out if you wish to use the DVD recorder. There are some currently available ATSC tuners that have built-in DVR capabilities. These might also work for you. However, many of the cheap units fail quickly.
I hope this helps.
Mar 06, 2017 | Televison & Video
Certain cameras are showing the same video.
First you need to isolate the problem. Step one - make sure the video from the cameras is correct - use a monitor and check each input separate. If the video is correct, use one camera and start from input one on the DVR and check all inputs - in other words plug your camera in input 1, check for video to make sure is correct and shows up in the right place, than go to input 2. This way you check your DVR cards. If the video shows up, but in the wrong place - check the settings on the DVR - you might be able to change the physical input in the viewer.Or you might have a bad DVR.......do a search for DVR Doctors in Google - in case you need repair.
Jan 27, 2012 | Avermedia AVerDiGi SA6832E RACK 32-Channel...
We cannot watch a show on another channel on other
Hello! Dan Busa here with DISH Network customer service. This is actually how your DVR is supposed to function. A 622 is a dual tuner reciever meaning it's capable of watching or recording two live shows at a time. When you record a show you tie up one tuner, there are two work arounds. You can get an additional dvr receiver or you can set up record preferences and have everything automatically record to tv2.
Jul 20, 2010 | DISH Network ViP622 DVR DTV Receiver /...
TV Guide onscreen is the wrong time
I've had this problem before, and always fixed it by going through setup again, setting the zip code to another zipcode nearby, and turning it off overnight. By the next morning the time has fixed itself. This is the only thing that has worked for me consistently.
Oct 22, 2008 | Sony DHG-HDD250 200-Hours Video Recorder
No Disc
I have the same model ... you can't use DVD-R or DVD-RW discs, only DVD+R or DVD+RW
Apr 26, 2008 | Cyberhome DVD Recorder - DVR1600
LG 50PX4DR 50 in. Plasma TV Logo
21 people viewed this question
Ekse
RONALD CARTER JR
