Philips Magnavox 27MS343S 27" TV Logo
Posted on Jun 08, 2009
Philips 21'' L01.2A AB Chassis; Dead, Standby LED off.
Set is dead and makes no sound. With PWR SW ON standby LED is off.
  • u_46479 Jun 08, 2009
    Fuse is OK. Resistor too. How to chk 7520?
Anonymous
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jun 08, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
Helped
2493
Points
23
It.s possibly a fuse, or a resistor, or regulator or all of the above
Why won't the set power up?
The red LED at the bottom of the TV is powered by the 5 volt standby circuit, if you don't have the light you don't have a 5 volt standby and without that the set is totally dead, no power going anywhere. Chances are a new power board will fix your set.
Samsung un40es6100f with no sound video or backlight. Would you agree this would be a main board issue?
Do you have a standby indicator in the front of the TV?..if you don't check the standby voltage, if its missing replace the power board, if you do test the PSON and see if its ok, if it is then its the power board if its not then the main. The PSON or it could be PWR-on as is the signal coming from the main board telling it to enable PFC and go to work basically, without that the set is dead but if you see that voltage then its a power board issue as the main is telling the set to come on
2answers
I have a bush tv its got sound but no picture
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Stuck on standby
I'm a little confused here as without the 5 volt standby voltage the blue light won't come on, the TV will be dead like its not plugged in, are you sure you were on the right pin when you measured that? It almost sounds like your on the PSON or PWR-ON pin.
29pt5301/15 chassis GR2.4AA Dead only flashing red LED standby. 148V on transistor horizontal, and 38V on transistor vertical is ok.
Check the frequency at the base of the horizontal output transistor. It should be in betwen 15.5 to 15.7 KHz. If you want more details about service help, try any service help sites. There are so many can be at internet.
1helpful
2answers
Dead set,flashing standby led
Have ordered new electrolytics for psu and will overhaul this when parts arrive.
Any further comments thro your site would be welcomed.
1helpful
2answers
Dead Set
No power, no sound. your tv is gona be dead set problem when they have no standby mode or standby ligth. need a repairman tech.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
