SOURCE: white spots have appeared on the screen mitsubishi
Bad Light Engine Call Encompass Parts 1-800-638-3328 or Try UED
1-800-648-6657
SOURCE: Mitsubishi dlp tv WD65733 has white spots, like
If you get White or black dots all over the screen (DMD symptom)
If you get a pixilated picture (DMD Board)
SOURCE: white spots appearing on the screen
Hi there it looks like you have a problem with the DMD board some of the micro morriors are getting stuck in the on or off position and that is the reason you have this effect I recommend to change the light engine system to fix this problem
PLEASE RATE THIS SOLUTION AS I DO THIS FOR FREE !!!!!!!!!
SOURCE: white spots on screen
Hi there you have a problem with the DMD board it sounds like some of your mirrors are getting stuck and that is the reason you have the spots in the screen you need to replace the LIGHT ENGINE to fix this problem
Testimonial: "Thank You!"
SOURCE: My mitsubishi 65-inch dlp tv
It's either mirror hinge fatigue or dust on the inside.
Mirror hinge fatigue can be fixed by putting a solid color picture (white or gray works best from what I understand) on the display and letting it sit for 20 minutes.
If it's dust, someone is going to have to go in there and clean it out.
Also could be a defective micromirror device.
Try the first suggestion and if it doesn't work, you're going to need a technician to take a look at it.
