Question about LG Flatron L1951S-SN 19" LCD Flat Panel Monitor
Lg lcd power board
Maybe the inverter board for the screen issue- the power issue seems to be LG has power board design flaw
    New Friend:
  • 22 Answers
Is it a moniter
Posted on Mar 07, 2014
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: LG Flatron LCD Power Saving Mode
Hi, September 2008 and still problems happening with the LG screens. Mine is a Flatron W1942T.
I hit the screen as suggested (my old mum was a great believer in " if it won't work kick it", this applied to anything electrical, tele, vacuum cleaner etc.,) and guess what? my old mum was right. The screen came on.
Hope this works if it happens again. I'd turned everything off because of an electrical/thunder storm. Won't do that again.
Joan
Posted on Sep 14, 2008
Nashk
  • 65 Answers
SOURCE: LG LCD Monitor won't exit Power Saving Mode
Does your desktop/PC display show anything before the monitor goes into power save mode? If nothing comes up, its possible that you have a loose VGA connection or that your video card/motherboard are defective in some ways. Try using a different monitor.
If the other monitor works fine with your computer, try changing/lowering the screen resolution. If in XP right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution. If in Vista/Win7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there. Then check and see if your LG monitor works on it.
If the other monitor also doesn't show any display, most likely the problem is either with your video cable or your PCs video card/motherboard, not the monitor.
Hope that helps. Good luck
Posted on Feb 16, 2010
bomark55
bomark55
SOURCE: LG w1934s lcd monitor's power led and display on-off blink
same problem, but not capacitors
Posted on Apr 12, 2013
LG 43LH5000 has blinking green light (power button).
Failing power supply. It revives, then fails again.
Jul 09, 2018 | LG Televison & Video
Black web hdmi splitter won't work,with my vizio tv
Maybe the tv main board problem,or the HDMI interface out of works
Abctay.com Wholesale tv parts,include TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
Jul 08, 2018 | Vizio Televison & Video
My LG 32in.TV I have the volume up to 100 and you can barely hear it
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
https://www.abctay.com/tv-power-supply-c-2
Oct 16, 2017 | LG Televison & Video
Tv is dim and can't brighten
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 28, 2017 | Televison & Video
I replaced power board for a Samsung TV model #UN40F6300AF installed today. TV still turns off. If i turn the the TV on 5 or six times the tv will work fine. Any other suggestions on what to replace
https://www.Abctay.com is an online shop ,
Mar 27, 2017 | Samsung Televison & Video
Why is my replacement LED Power Supply Board not functioning properly?
Power supply board is not the culprit - check out your inverter board which is responsible for the back lighting.
Feb 03, 2016 | Samsung Televison & Video
LG 32LC2R 32 inch Wasworking ok, now blinks 5 times
Seems like you have an Inverter issue
Inverter board is under the psu to the left and its job is to
light the lcd panel so you can see the picture
give me more info and i might help you to fix this
Aug 17, 2014 | LG 32LC2R 32 in. HD-Ready LCD Television
My LG 26LH20 turns itseld off after about 2-3 seconds. TV is a little over 1 yr old. I t happened about 2 months ago and I thought it was the cable. had cable serviced, not the problem. now it's...
Tv turn itself off after 2-3 seconds the tv still audio voices?Yes,than the tv long board that call the LCD inverter board it is dead.Require change the tv long LCD inverter board,this board help the LCD screen panel to have a backlight to produced a picture or 2-3 seconds tv power died completely no power to tv all?Yes,than this problems the tv power supply board it is dying.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board or the tv power supply board for the replacement.
May 09, 2011 | LG 26LH20 LCD TV
No picture after 20 mins on LG LCD Tv
i have a 32" lg hd flat screen an it now does the same thing i got it on boxing day an its not even 5 months old
Feb 21, 2008 | LG RZ32LZ50 32 in. LCD Television
SCREEN AND POWER CUT
maybe the inverter board for the screen issue- the power issue seems to be LG has power board design flaw- basically last time I looked the power board is manufactured NOT by LG but by H&E ...who designs this stuff??
Dec 15, 2007 | LG 42LC2D 42 in. LCD HDTV
LG Flatron L1951S-SN 19" LCD Flat Panel Monitor Logo
93 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
