When I turned on the demo I got more of the same. The instruments would go in and out with random synth sounds and the volume going in and out.
SOURCE: CASIO PX575R
This may be a hard one to analyze, however my educated guess is that a static discharge is putting the internal processor in a program loop it shouldn't be in.
It is my experience that you MAY not even feel a discharge even.
Suggest you make sure to not wear static producing clothing as a test. Sliding across a piano bench might even create the discharge.
The unit SHOULD not be sensitive to this, but the designers don't always do things right.
ALSO make sure the unit is plugged into a grounded receptacle.
Use of external things like amps and headphones can WORSEN the problem of static. External amps MUST be fed from the same receptacle.
SOURCE: Casio keyboard lit up, no sound, no responses
Unplug for several minutes and try again.
If that doesn't work, look up the "factory reset" procedure for your particular model via google and follow that procedure. It usually involves holding certain buttons down before and during power up.
