Sony BDP-S350 Blu-Ray Player Logo
Posted on Jun 04, 2017
Sony BDP - S350 freezes up often playing DVD
Approximately every 3rd disc I play in this new player freezes up at some point during the playback.  I usually remove the disc, look for scratches, etc.  Usually find one  - sometimes tiny, sometimes bigger.  Then I'll clean the disc and this usually doesn't help but does sometimes.   If this doesn't help, I'll usually finish watching the disc on my computer which has much less "sensitivity".   Should I return this player? Robert
5 Related Answers
Anonymous
  • Posted on Jan 18, 2008
SOURCE: Player freezes during movie
i have the same problem, i put any dvd and it freezews during the play. there is nothing to do, must restart and sometime have to wait one day before i can restart. i have tried at leat 12 different dvd and it freezes everytime on every single one of them. I have tried clening... no success. Now Sony replacement plan cost 150.00!!!! I have paid 200.00 for the player. At this point i hsould buy a new one or get a replacement? Probably replacement but at that price I feel i am buying a new one.... I am disapointed with Sony. Don't buy DVP-FX810 seems i am not the only one with the problem.
Anonymous
  • 254 Answers
  • Posted on Apr 03, 2009
SOURCE: DVD stuck in sony blueray player bdp s300
Step1There are a few ways to get your dvd/cd drive release itself. The first thing you should try is shut your equipment completely off for a couple of minutes allowing it to cool down. Once you turn it back on try to press the release button on your equipment. Step2If that does not work try to use a very thin flat tip screwdriver. Insert in on one of the sides of the dvd/cd drive and try to pull it out softly while pressing the eject button simultaneously. Do not force it out but give enough pressure while pressing the eject button. Step3More than likely inserting a screwdrive should release the dvd/cd drive. You can also try a butterknife as well just don't use to much force. Something else to check for is to make sure the power is acutally on for the device. If you are trying to open a drive that is not even on it will never open up for you.
tomazbodner
  • 3 Answers
  • Posted on Apr 15, 2009
SOURCE: SONY BDP-S350 MULTIREGIONAL PROB
You should get Asian firmware.
They are (despite printed DVD Region 3, BD Region A) all DVD region free. Tested on mine (bought in Thailand).
Panasonic BD30 was also DVD Region free. The firmware for that one is available from Panasonic website. Not sure if there's another way than automatic update from inside BD player to upgrade Sony.
Anonymous
  • 3 Answers
  • Posted on Jun 02, 2009
SOURCE: Bravia indicates no signal from Sony BDP S350 DVD
I once had a similar problem, although with a different TV. It was insufficient to just power down the TV -- I had to unplug the TV so that it would re-initialize. It solved my issue.
Mykel_N
Mike Neath
  • 315 Answers
  • Posted on Sep 01, 2009
SOURCE: Unlock Region code for Sony BDP S350 bluray player
Hi john,
There is a lot of information here about that unlock, it doesnt look simple though which is why im going to post the link instead of the whole procedure.
Sony BDP S350 Region free
I hope that makes sense and helps
Mike
My sony bdp-s350 can not play netflix steaming
I'm sorry to inform you that the Blu-ray player does not have the feature to stream videos from Netflix. The network connection on the player is used for watching BD Live content from the playing disc and network update.
Thanks for understanding.
Please let me know if you require any clarifications.
11helpful
Won't play disc "cannot operate this disc" "cannot
I was able to fix this on my BDP-S350 by resetting to factory defaults and pulling the power cord on the system. It takes approximately 1 minute for the capacitor to completely drain the power. Once I replugged and powered up the system I was able to play a disc that minutes before had said "cannot operate this disc." Hope that helps.
Uxpendables blu ray won't play on my bdp s350. It says Unknown Disc. update not needed I already checked.
is that the only disc that wont play? have you tried inserting memory stick on bd player. format memory stick (atleast 2gb) first to fat 32 using computer. insert to usb slot of bd player. then try to play the disc again...
I have upgraded the firmware of my BDP-S350, but still will not play any blu-ray discs. It plays dvds just fine. The error is "unsupported disc".
has it ever played blu-ray's properly any odd issues leading to this problem and it could be a weakened laser these are just more expensive dvd players that are just as prone to wearing out hope this helps you:)
It freezes when playing a blueray movie. it seems
The most likely cause of your frustration with the BDP-S350 is that your player's firmware is not the most current. Most often, the firmware problem is JAVA related and will not let the menus load at all, but freezing during playback has also been reportedly fixed with the firmware upgrade.
The solution is to go to sony's website, download the firmware upgrade, burn it to a disc and then load the disc into the player to fix it.
I hope that helps.
Blu Ray player turns on, displays "Welcome on the screen. After disc is inserted, "Wait" appears on the the screen and then it freezes. What is wrong?
This sounds like your Sony player is not reading the disc.
I have bought faulty DVD discs before that have given this same fault!
- I assume you have tried a disc that you know works in another DVD player?
Remember, your Sony Blu-Ray should be able to play ALL REGIONS of standard format DVD discs, so you should get sound & images from any one you choose.
2helpful
2answers
Crank 2 will not play in Sony S350
The software updates for your Sony BDP-S350 can be found at their website here. You will need to download the file, burn it to a disc and then load the disc into your player to upgrade its software to play your new blu-ray movie.
I hope that helps.
18helpful
3answers
SONY BDP-S300 unlock region code
DVD PLAYER SAYS CANNOT PLAY THIS DISC
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
