Brother HL 2700CN Laser Printer Logo
m
melissa17900 Posted on Feb 11, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unload output tray
Not full
Printer Help & Support
Level 3:
  • Brother Master 783 Answers
  • Posted on Feb 24, 2014
Brother Master
Level 3:
Answers
783
Questions
0
Helped
280003
Points
1637
The Tray Full indicator lights on the appropriate stacker tray
(applies to dual stacker only).
A message displays on the printer control console that
indicates which output tray is full.
In automatic switching mode, the system automatically
switches over to the second tray (if it is empty) when one
tray is full (applies to the dual stacker only).
If only one tray was selected or if both output trays are full,
the printer stops.
The picture on the graphic display shows the location of the
full tray.
Still having Problem Then follow Us For
Brother Printer Support
My icemaker will not dispense ice. The tray is full, but won't rotate to drop cubes.
Ice sitting for a long time in the tray sometimes freezes the mechanism. Try unloading the tray of ice. Make sure nothing is jamming the parts that dispense the ice. Wait for new ice to be made and see if it works.
Phaser 8860 Unload output Tray
Take out the paper! just kidding :)
I guess it's a problem with a sensor in the output tray that has either fallen off or got stuck in an up position by some paper.
Either you put it back, remove the paper that is stopping the sensor from moving freely or call an engineer
Unload output tray
Apparently the machine is telling you to remove the copies made from the output tray, probably it is getting heavy.
My photocopier (Canon iR1600) displays a message that the output tray is full when i try to photocopy
hi . check the flag sensor in the output tray . if you move the flag sensor up it should come down when you loose it
1helpful
FABRIC SOFTNER TRAY STAYS FULL AND IS NOT RINSEING OUT
HiYa dh1200s
The softener tray needs to be cleaned out or the sensor for this replaced.
Yes, not enough water entering machine so not enough water to rinse out the softner
Please leave a good rating before you sign off.
11helpful
2answers
Ricoh AP3800C "Output tray full"
Check the little black piece of plastic that senses the printed page exiting the machine. Our sensor was stuck and I was getting the same message (an similar Ricoh product). When I gently reset the black piece to center, moving freely, printing worked again. I think the sensor got jammed up when we were trying to remove a bad paper misfeed.
Ricoh manuals very confusing on this error message. They refer to standard tray, tray one, etc. without being clear whether it's a paper feed tray or the so-called "standard OUTPUT tray." The output is not really a tray, it's just the depression where your sheet lands after printing. I wrenched on the paper feed trays and their settings for an hour before I figured out they meant OUTPUT.
I have a xerox document centre 420 which is saying centre tray full please unload documents but nothing in the centre tray please help
There is an actuator that is knocked off its mounting.
It is towards the front of the machine, right by the output rollers.
It would be about 3 inches long and have a couple of flag shaped lobes on it. All it needs is cliped back into place. There are 2 metal tabs with holes in it to insert the ends.
That is your problem.
9helpful
2answers
Output tray is full
Hi, there must be an actuator of the output tray sensor.It is placed above paper tray, just in place when paper exit from machine.Try to clean sensor,or to place actuator in proper place-pull it down.Also,maybe is actuator broken.
Norman Weimar
Norman Weimar
k24674
