SOURCE: Washer does not spin
There are several causes for this problem. Check these.
These are the causes that have to be inspected.
You can also visit this site www.whirlpool.com/custserv/index.jsp
Hope my info solves your problem,
Thanx for using fixya,
Good luck.
SOURCE: Fills but will not agitate, spin, or drain, motor sounds strained
i have a whirlpool that go threw a wash cycle, but will not shin out the water
SOURCE: whirlpool top loader washer not agitating
Hi, Do you know if the lower half of the agitator is working? THere is a dog kit that might need replaced in the agitator to get the top half to work. If neither half agitates, there is probably a transmission issue. Start the washer with no laundry in it and see if either sections of the agitator work.
I hope this helps you.
Vic
SOURCE: Whirlpool topload filss, will not agitate, spin or drain.
This sounds like you need a new motor coupling and an agitator repair kit on this unit. We have parts and will be happy to assist you with your repair.
When you purchase your parts through us, we provide part removal/installation instructions.
You may contact us at:
WWW.Accurate-Appliance-Service.com
We look forward to working with you and hope this gets your washer in good working order again.
Have a great evening, Ella
SOURCE: Wash is not agitating properly. Top portion of
inside the agitator there is a set of 4 gears that make the top part of the agitator go back and forth pull off the top and remove the nut inside pull on the very bottom of the complete part then take the top part of the agitator apart from the bottom the install the new new gears by replacing the old ones reassemble and it will work properly
