SOURCE: Sharp AR-5316 photocopier & printer driver
Sharp AR-5320 photocopier/printer is in share network. for each printing command ,its asking to install driver.and its taking more time for printing..
SOURCE: my sharp ar 5316 photocopier displays h4. what
press # interrupt c interrupt . Display goes off
press 14
SOURCE: How i will enter in Sharp Ar 5316 photocopier
Hallow there, it is always good to understand a specific code and what it means because not all codes are cleared using simulations. Maintenance sign means that the copier needs to be well serviced and checked if something is to be replaced. Consumables such as drum, blade, fuser rollers and developer are changed at such times. If you are sure that you have replaced the correct part or nothing is to be replaced, then you can proceed to clear the sign.
Follow this procedure to clear maintenance sign; Press #, Interrupt, C, Interrupt. keys in that order. Enter 20 and press copy key then enter 01 and press copy key again then press CA key twice to return to normal mode. Wish you success.
SOURCE: how to enter in the
Try pressing #, *, C, *, to get into the simulation mode. To change user settings, try the menu feature. Good luck.
SOURCE: i have a sharp photocopier AR-5316 flashing error
i have a sharp photocopier AR-5316 flashing error code is E7 how to reset this code and solve the problem
