Question about Spa And Pool Store 03-0169-48 - Artesian Spas 6" Waterfall, Lo-Profile L.E.D
Waterfall has low water pressure when jets are on
    Problem Solver:
  • 29 Answers
Turn the control knob that works the waterfall
Posted on Jan 17, 2015
6ya staff
SOURCE:
Pump running no water return to pool
if pump basket full of water make sure connected correctly front line is intake from pool back top is out to filter in filter out to pool return if sand or DE filter make sure lines correct and in filter position
Jul 17, 2018 | Pool Pump Pool & Spa
Water just trickles out of the waterfall faucet
Look for the obvious-take off the screen. Then you may have to venture into the faucet itself. If you have galvanized pluming, every time you shut the water off, scale will fall int the center of the piping without pressure and then when you open the faucet it tries to flow through small orifices.
Dec 13, 2013 | Garden
DREAM MAKER SPA WATERFALL VALVE
The threaded cap the holds the waterfall valve in place is most likely cracked so you will just need a new valve. Send me a picture of it and I can see if I can locate one for you.
Jul 30, 2013 | Pool & Spa
Poor hot water pressure form Delta single lever faucet
it can be adjust take handle off and remove locking collar first turn water off,
it has a metal or plastic ball with a shaft for the handle it may have spun or a washer may be bad under it,
you can get a replacement at lowes or Home depot to replace it if this is the problem .
Apr 25, 2010 | Delta Model 172: Waterfall Single Handle...
Low water pressure in gas califont
by contacting the manufacture they can tell you how to do that.
Apr 12, 2010 | Jet Flo 04325143A Marine Heavy Duty Water...
LOW OUTPUT WATER PRESSURE
Pull the bottom strainer off and check to see if their is anything in the impeller.
Feb 14, 2010 | Pondmaster Mdwp30 - 3000 Mag - Drive...
Low water pressure while the rest of the faucets
lume build up. pull handle out and unscrew there should be filter inside take out and soak in a cup of lime away overnite rinse well and reinstall
Dec 17, 2009 | Delta Faucet Delta 474 Waterfall Single...
No pressure on certain settings
Dear Osville,
It is not clear what type of lance or nozzel you have. You said that the machine works fine with the circulating water jet(the turbo). So it seems the machine is fine. I do sometimes service variable nozzels and variable lances. But the best solution is to replace nozzels and variable nozzles and lances with new ones. Regarding the fan spray setting it could have no pressure because it might be in the chemical setting. The chemical setting lets out a fan shape flow of water, but with less pressure. The chemical system only works on low pressure in domestic washers, that is why it needs a low pressure flat spray. The pencil jet has 2 jets comming out because if it is a lance or nozzel with ball bearings, these ball bearings must have stuck in a wrong position. Also 2 jets can come out, due to a damaged nozzel hole.
Altogether, the best advice is to buy a new nozzel or lance...which ever your machine uses. All Karcher machines have their own specific nozzels, lances and high pressure hoses. You cannot change these from one model to another.
Regards,
Fulltech.
Apr 29, 2009 | Alfred Karcher K 5.93 M Electric Pressure...
Leaking waterfall faucet
You can go to a hardware store or lowes,Home Depot and buy a repair kit for it.When pick up the kit make sure the model you have are listed on that kit.Most of them come with a allen wrench to take it a parted. It's easy,but turn the water off first.
Mar 17, 2009 | Delta Model 190: Waterfall Single Handle...
Low water pressure
IF ITS PUMPING FINE-( NOT RUNNING, PUMPING ) YOU PROBABLY HAVE A LEAK SOMEWHERE DOWNSTREAM. IS A WELL OR WHAT IS THE PUMP USED FOR?
Mar 14, 2009 | Jet Flo 04325143A Marine Heavy Duty Water...
Spa And Pool Store 03-0169-48 - Artesian Spas 6" Waterfall, Lo-Profile L.E.D Logo
303 people viewed this question
Top Spa And Pool Store Pool & Spa Experts
Bill Jordan
john h
David Spradling
David Spradling
Are you a Spa And Pool Store Pool and Spa Expert? Answer questions, earn points and help others
