Several things may be happening. Most likely, you need to adjust settings on the cable box for HDMI output rather than component or composite RCA. The same may be true for the TV. Did you check your input source setting on the TV? Also, go into the Video Settings menu and see if the TV asks for types of cable input for video, and audio settings for audio input from the HDMI.
The HDMI cable is for connecting the camera to an HD TV. If you want to connect the camera to a computer, use the USB cable.
Better yet, don't connect your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
The PS3 can be hooked up to the tv using either a HDMI cable or the old RCA (Yellow, Red, White) cables. If you are having problems viewing a picture or hearing sound, here is some trouble shooting you might want to try.
Connect the PS3 using both the HDMI and RCA cables. select the HDMI input on your tv. turn on the PS3. If you cant see a picture, press and hold the power button until you hear 2 beeps (this will take about 15 seconds). This resets the PS3 to the old RCA cables. Select the RCA input on your tv. Hopefully you can see the image and hear the PS3 now. Go to the settings on the PS3 and change the display settings to output video through the HDMI. Remember, your tv can only go as high as 1080i resolution, so you wont see anything if you select the 1080p resolution.
If this didn't work, you might have a bad signal though the HDMI cable. Unplug the tv and PS3 for atleast 30 minutes, and then connect the PS3 to the tv before you turn either one on.
If this doesn't help, then you might have a HDMI cable that isn't recognized by either your PS3 or your tv. Try replacing your HDMI cable.
Try another HDMI cable. I have seen them become defective. If it is not the cable, then try another HDMI device to test the TV.
Without an HDMI cable tester, and a way to measure the output of the HDMI source device the only way to resolve this is with the process of elimination.
Jerry G.
