Lands Phones Logo
Ian Westall-au Posted on Jun 08, 2009
Doro 80 How do i set the time on the hand set Thanks Ian
A
Anonymous
If you get caller ID, it will automatically set the caller id on an incoming call Otherwise: Press the OK/Menu button scroll to DATE/TIME using the up and down arrows, then press OK Enter Month (01-12) press OK Enter Day (01-31) press OK Enter hour (01-12) press OK Enter Minutes (01-59) press OK scroll to AM/PM using the up and down arrows press OK to save settings
2answers
How can I get rid of red X in left hand corner of Doro 6520 mobile phone - it says on screen SOS Emergency Calls only?
Turned off phone, turned on again, looked for settings(now there), flipped thru contact/message/etc screens, and it now works! Wonky fix, but now works.(I HATE this phone)
1helpful
How to remove red cross in top left hand corner on doro 6520
I believe it indicates a loose memory card, but I didn't see it in the manual.
Free manual from the manufacturer's web site:
https://www.doro.co.uk/doro-6520.html
1helpful
I require a manual for Doro Phone Easy 611
Go to http://theinformr.co.uk/cell-phones/doro-phoneeasy-612/ and click on the link on the right hand side under downloads, to download the manual for this phone
Thanks
2helpful
Have Doro 635IPW, lost sofrware cd, software's discontinued, what now?
Go to http://www.doro.dk/support/. Scroll down and on the right hand side, open VOIP-Downloads. Get the DoroUSBPhone_635ipw_1,1,016.zip file.
Haven't checked if it actually works, but at least it's a start :-)
2answers
DORO NeoBio 10 Cordless Phone
The hand sets probably need to go through the 'registration' process with the base station. Look up the steps on how to do this in your manual.
One thing that the manual sometimes does not highlight clearly is that first you need to press and hold down a button on the main base station for a while until it beeps. Then you can go through the menu on the hand set to complete the registration process.
1helpful
4answers
Doro 133R phone - answering machine not working
a bit late for this persons problem, but if anyone needs a manual here's the doro site - just type in the model number and you will be able to download the pdf.... http://www.doro.com/global/businessunit/dorocare/support/imagesdownloads
3helpful
3answers
Doro 130 R
Go to http://www.doro.com.au select home phones then Support then Manuals Then you type in your model which should be on the back of the base unit.
Top Lands Phones Experts
k24674
Are you a Lands Phone Expert? Answer questions, earn points and help others
