And they dials wont turn, so I can lift the weights
SOURCE: have boweflex selecttech dumbbells and one set
Either the handle is broke or try making sure all the weights are facing right way (same way) or the handle will not sit all the way down. It needs to sit all the way down for the button on the bottom of the handle to be pushed to release the adjuster to be able to spin and grab weights.
SOURCE: once the dumbell is on
Try setting the handle in the plates back onto the carrier(bottom). Lightly tap on each plate that is stuck. Now push the plates down (vertically) onto the bottom carrier. Now try turning the dial (side that was stuck). It worked for me. Have my 1090 plates were stuck on the handle. Good luck
If you're
weighing in the 140-170 lb. you should buy a punching bag weighing around 70-90 lb. if your close to 140 you
should buy a 70 etc. if you a big guy weighing over 170 lb. you should get over
100 lb. bag. There is also heavy punching bags suitable for children and the
weight around 25-55 lb.
Hi Fernando Acosta, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box? one one weight, the dial on one side is stuck at 70lbs and the dial on the other side is stuck on 90 lbs. I can't turn the dials or lift the weight
