Coby Kyros 716829701508 Tablet PC Logo
Krista Sharp Posted on Feb 12, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tablet wont turn on
It wont turn on and wont charge the screen just stays black
Mark Mc
Level 2:
Sergeant:
  • Expert 281 Answers
  • Posted on Feb 13, 2014
Mark Mc
Expert
Level 2:
Sergeant:
Answers
281
Questions
Helped
42149
Points
692
If the charge light comes on then the unit may need to be replaced. Try connecting it to a PC to see if it detects it. If it does, you may be able to reinstall the firmware.
Wht if tablet does not turn off after u hold the power button
What to Do When Your Android Phone or Tablet Won't Turn ...
www.howtogeek.com/.../what-to-do-when-your-android-phone-or-tablet...
May 16, 2015 - android wont turn on. You turn on your Android phone or tablet by pressing its power button - simple. If that button won't work, your device isn't necessarily broken ... often see an "empty battery" indicator on the screen when you try to turn it on. ... You should only have to hold the Power button down for ten ...
samsung tablet wont turn on - Samsung - Android Tablets - Tom's Guide
www.tomsguide.com/forum/id-2155281/samsung-tablet-wont-turn.html
3 days ago - 43 posts - ‎36 authors
I charged my tablet and turned it off for a few hours and now it wont cut on
Press and hold power button for a few seconds.. To run safe mode.
This is a common problem caused by power fluctuations.
My tablet wont turn on unless connected to a power supply and when its connected the screen stays black
I'd check the tablets internal battery and also the cord and plug from the charger. Though the cord powers it enough to run the connection may be too insufficient to -keep- the battery charging. I would also turn the device completely off while troubleshooting.
Rca tablet model rct6272w23 screen pixalted white then went black now wont turn on
I would recommend calling RCA support at (800) 252- 6123 so they can suggest some troubleshooting steps you can take. If it is still under warranty and you're unable to get it working then you can send it back and get a replacement
My tabet wont turn on
First make sure your charger is working properly. Check it with a volt meter or use a friends charger that you know is working. Charge your Coby Kyros for 4 hours. Use a small needle and gently insert in into the "reset" hole on the back cover on the left side. Hold it down for 5 seconds then release. Try restarting your tablet. If these don't work, you will have to get professional help to check it out.
Why wont my skypad alpha 2 turn on
Hello, My SKYTEX Device (Tablet) I've had mine for about two weeks so far, well recently my SKYTEX device has been acting I don't know why?!
This morning I wanted to get into my tablet, I couldn't because it's NOT working, what it is, I'll be charging it, and thinking it turned off, I don't know why, my screen just stays black, and any advice how I do reset it as it was NEW from a computer?
Thank!
Top Coby Tablets & eReaders Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
