Does the toshiba 57H81 need a converter box or just an antenna? I tired all solutions with just free air television but it will not show...I used the APexdigital dt250 converter but it shows no signal please help to see what a may be doing wrong.
SOURCE: Comcast cable service Scientific Atlanta Digital Box will not let us use PIP on their cable remote.
If you have a digital converter, then you are only able to watch that converter on the input it is on. However you can split the cable before the cable box and run 1 side to the box and one side to the rf in on your tv
SOURCE: Blinking power light & black screen on toshiba 57h81
This TV could have one of several problems including but not limited to; convergence IC's,bad capacitors, shorted horizontal output transistor. Call a good TV Tech. Check with the BBB before you decide on one.
SOURCE: Trying to manually fix color convergence on Toshiba 57H81
The convergence ICs and the six 1.8 ohm 1watt resistors need to be replaced. You can get the convergence repair kit for your model at www.tvrepairworld.com which has the Two Convergence ICs and the six resistors plus the CD with instructions on how to do the repair.
Testimonial: "Thanks! I'll give it a try!"
SOURCE: my toshiba 57h81 tv is showing up double vision
This tv have a problems known as a Convergence problems,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.This parts must be replaced to solved the convergence board problems.The shop will cost u $300-350 for parts and labors.
