How do i reset my nikon coolpix p90 back to factory settings?
SOURCE: nikon coolpix p90 how to reset to factory settings
It doesn't reset everything, but there is a "Reset All" command in the Setup menu. Press the MENU button, then the wrench and then "Reset All."
This reset leaves the date/time, white balance, language, and video mode alone.
SOURCE: Where can I buy start up disc for nikon coolpix P90 camera
You can download the current versions of all (free) Nikon software from here.
You don't need any software in order to use your camera. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
