Sennheiser E835 Professional Microphone Logo
A
Anonymous Posted on Feb 12, 2014
Can not take mic off mute - Sennheiser E835 Professional Microphone
How can I turn off the mute function?
If it is a VTech phone ( CS6429 or similar )
press the [mute] button again: it is a toggle.
First press of [mute] turns mic off (mute-on).
Next press of [mute] turns mic on (mute-off).
How to unmute my Samson Meteor Mic?
There are 2 ways to mute or un-mute the mic:
  1. Push the button on the front of the mic
  2. On the computer, open Recording Properties and go to the Levels tab and click the speaker icon next to Microphone slider.
1helpful
Logitech G930 Echo problem
Check the device manager for duplicate devices and make sure that the on board devices are disabled
2helpful
When calling,i can hear the person i called but they cant hear me
Hi..
Looks like problem is on your side. This is may due to a faulty microphone on your phone or Mic is set to be on mute.
1. Please check that nothing is clotted on Microphone. This is a small hole on bottom side of your phone.
2. Please check that other party can hear you when you're using a Hands-free / Bluetooth ear phones with mic on it. If they can hear you, when you use a hands-free, problem is with your phone's on-board microphone.
3. You can also check that, while on a call, your mic is not set on Mute. This can be done as on call, select Options , look for Mute / Unmute. If Unmute is present, select it unmute the mic.
4. You can use Mute button Provided on the top side of the phone. While on the call, press this button to Mute / Unmute the mic. If the mic is set to Mute mode, other party won't hear any sound from you.
Hope this will solve the issue.
I have been using Plantronics 995 for several weeks. I quit working without any system cnanges. Have tried re-paring, and reset all audio settings to plantronics. Bought replacement unit ( plantronics...
this is a normal reaction ..specially on a wireless device ..the idea is to lower the volume into the computer ..(to max 80%)..and also get into the volume control by double clicking on the speaker icon in the task bar ..and in here look at the mic volume
if there isnt any volume section for the mic..than click options ..than properties..and from the list tick the case for mic in ..and will list the volume for mic..
if the advanced function is on ..check into the advanced under the microphone it is started the mic boost function ..if it is ..and you want to keep it for a better mic reception ..than you have to put the mic on mute to eliminate the static noise..
THis should not mute it for good..but you can make a trial to be sure..
If the advance boost function is on ..and the muting puts it out for good..the choice is to get rid of the boost but usually works if you mute it ..cause only mutes the noise ..
let me know if you didn't understood anything ..
9helpful
2answers
Nokia 6120 classic mic got muted?
if remove mic point, then jumper from ic
Microphone doesn't work on Logitech ClearChat Premium PC headset. I've checked jacks, mute switch. Ran Paretologic to install proper drivers. Is there an on and off switch for the microphone (not the...
If the mic mute switch is not on and there is no red light in the mic arm then its likely you have a check in the 'mute mic' box in your sound manager. Open Volume control, choose options->properties-> recording. Check for checks in the boxes and remove them. Also make sure the slider for the mic is about half way up.
2helpful
No audio
After starting the webcam go to the Volume icon in the system tray and un-mute the Mic. Some Windows is in a habit of muting the mic very often. So every time you want to use the mic, um-mute it from this icon.
Mic muted
Just check the button on the mic or the properties of the mic... from there only you can select the option to not mute.
Laptop acer
Hi please check the audio properties settings of your system . The MIC would have been MUTED . Uncheck the mute against mic and you should be able to record thru the built-in mic.Right click on speaker icon in taskbar audio properties under mic uncheck in the box beside mute.
Top Sennheiser Audio Players & Recorders Experts
 Grubhead
Grubhead
john h
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
