I am so frustrated with this problem. It is most noticeable with towels. The clothes have a very nasty odor to them as soon as they become wet or damp.
I also have the problem of water being left in the washer. You can't see it but when you move the drum back and forth after removing the clothing you can hear it splish-splashing back and forth.
If you open the door of your Neptune, you'll notice a small trough between the door gaskets (inner and outer) There is a drain at the bottom that can get blocked by lint and other funky stuff. Next time you do a load of towels, take a small dirty towel and wipe that area of your machine out real well. Secondly load a slightly smaller load in your machine. Be sure to use a HE compatible soap...less foaming- it does make a difference.. Also the swishy slushy sound is normal and there is liquid in the drum for balancing...it's normal.. I think with a clear door drain, a bit smaller load .you'll find it won't be smelly.. I've got one of these and the only time it gets ordoriforous is when I've jammed it to max capacity. Let me know if all this helps you out. k
Same problem here. I cleaned the seal around the tub and washed a few loads with HOT water and BLEACH! It did stop the washing machine itself from smelling. As for the clothes that already smell really bad.... drying them in the hot sunshine takes the smell out until washed with other still bad smelling clothes (like thick towels). As for my towels and washcloths, I finally just washed them all with BLEACH, no matter what color they were, and it worked great. I didn't care if they were lighter blue or green, just as long as they finally smelled clean!
The water that remains behind in the Maytag Neptune for "balancing" is the problem. It is never completely replaced or sits stagnant for periods between washings. There was a class action lawsuit about this, but I missed the deadline. Anyway there is reportedly a way to drain that old water before starting a new load of wash by using a combination of the spin and rinse cycle. What would be logical to someone who understands how these things work?
