SOURCE: Problem with my Konica Minolta bizhub 350
The code is for fusing warm up failure. Turn the machine on, wait for the error, then open the front door - you will see a cover on the right hand side which you need to unscrew and remove, behind that is a board (PWB-S1- Tech. Rep. Setting Switches Board) press the trouble button then reinstall the cover and shut the door. Your printer should now reboot - if the error comes back you will need to have the fuser either repaired or replaced.
SOURCE: Error Code C3451 in konica Minolta Bizhub C200.
You will need to replace the thermostat and the best solution is to call a technician.
SOURCE: HOW DO I SOLVE ERROR CODE C3451 IN KONIKA MINOLTA
You will need to replace the thermostat and the best solution is to ask a technician to do that.
SOURCE: konica minolta bizhub c250 error code c3451
this probably happened first thing in the morning when turned on lets try to reset power the machine off using the switch inside the front door not the one on the panel now press and hold utility button down and turn machine on keep the utility button pressed until the trouble reset light comes on press the trouble reset it should flash ok now using the switch inside the door power the unit off wait about thirty seconds and power back on this should fix the problem if not you will need a tech to come out good luck
