Frigidaire GLTF2940ES Front Load Washer Logo
A
Anonymous Posted on Feb 13, 2014
Water in drum after cycle finishes
Water in drum after between cycles
Jorgie the appliance guy
Level 3:
Top Expert:
  • Frigidaire Master 5,639 Answers
  • Posted on Apr 01, 2015
Frigidaire Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1523794
Points
32630
BAD CLUTCH OR LOOSE BELT
3 Related Answers
Anonymous
  • Posted on Mar 24, 2009
SOURCE: high speed drum rinse ..drum not spinning during rinse cycle
Clean out coin collector thoroughly. Replace drain pump if necessary. Water will drain if you can place drain hose on floor and let water siphon out.
Anonymous
  • Posted on Jan 25, 2010
SOURCE: water in the drum
My front loader will only start up for a second and then shuts down. I have already taken the water pump off and found no debree in this area . Any Ideas.
Anonymous
  • Posted on Nov 24, 2010
SOURCE: My 2006 Affinty front load washing machine does
This has been going on for me, too, for over a year. Replaced control board and does not seem to make a difference.
Maytag washer 2000 series model YMHWE251YL00. Does not finish final spin cycle. Error codes F9 E2. Please help!
If you go to web site for clarification of the codes you will know exactly where to look in your machine. If not finishing spin cycle there may be an issue with the belt drive that spins the drum to remove water.
1helpful
Doesn't dry clothes properly after spin cycle clothes are wet when cycle finishes It empties water
Bad belt will not allow drum to reach full rpm during spin cycle, not spinning all water out of clothes
WFW8300SW05 WON'T FINISH CYCLE
This is down to one of two problems, number one is the pump or filter blocked? if the machine is unable to drain it won't go into spin mode and finish the cycle. number two there is a pressure switch which detects wether there is water in the drum, there is a tube going from the drum to the switch which can get blocked giving a false reading, so even if the drum is empty it won't go into spin if it thinks there is water in the drum. hope this helps.
2helpful
The washine machine finished it's cycle but there was smoke coming out of the drum and a burning rubber smell
The usual cause of smoke coming out of drum is that the heater element has come on or stayed on with no water in the drum
Try it on a spin cycle only, if smoke still comes out of drum, then could be a faulty pump, or main motor is burning.
My washer won't drain near end of cycle. Motor
The problem will be on the main board or the power supply board of the machine might have some problem kindly the check the wire lines as well
i do not think that drain pump is having any problem
Water remaining in drum not finishing cycle
Your drain pump motor is either stuck or defective. Suggest you remove it and inspect. Clean it by the impeller and reinstall. Most of the time motor only needs cleaning. Let me know.
Oct 14, 2009 • Dishwashers
1helpful
2answers
Water appears in drum after wash cycle is finished.
if you remove the front cover there is a drain plug that holds change and lint paperclips etc, it fills up and gets plugged and wont go throught the drainig pump. if you find this and clean it out you will be good for another 6 months...its important to check pockets before washing
1helpful
Washing machine begins the wash cycle going immediately to the agitate cycle, without filling up with water first.
water will not stop running into drum unless shut off at faucet does not happen all the time and wife can't find her rubber boots
I have a maytag washer-n-dryer(stacked). When the washing machine is filling in the wash cycle of the delicate or the permanent press cycles, it will not stop filler the drum with water. The washing...
it sounds like your water inlet valve is bad,change it,also try your washer on another water level like small load or med load and see if it cuts off,it might also be your water level switch,hope this helps,thanks-mike
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
