Samsung Digimax S500 Digital Camera Logo
Posted on Jun 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Broken NIkon Coolpix L18 screen
I stuck my Nikon Coolpix L18 in my jacket pocket and closed the snap, and apparently such a gentle force cracked the screen. Now there's a big crack in the middle and the screen is white with big black spots on it. Does anybody know an inexpensie place I could buy a new screen or something to fix it? Because if I send it into Nikon to fix it, it'll cost almost as much as if not more than the actual camera itself cost me. Your help is much appreciated!!!
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Samsung Master 102,366 Answers
  • Posted on Jan 04, 2013
Samsung Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428578
Points
622693
One source for the part is here.
  • kakima Jan 04, 2013
1 Related Answer
Anonymous
  • Posted on Jan 02, 2009
SOURCE: broken nikon coolpix L18 camera screen
I just spent a whopping 10 minutes removing 6 small screws. I had to wrestle it a littl to seperate the case, but once open the screen lifts out. Attached to a ribbon cord. Carefully unlock the cord, replace LCD, reassemble. I'm seeing about $55 bucks for this screen. You can do it yourself.....Good luck.
Distorted and brown leaves at end of shoots no flowers also small holes in leaves close to leaf veins.
Apparently this question has nothing to do with the Nikon L18 camera. Please repost in a more appropriate area so that the proper experts can see it and provide a solution.
My nikon L18 coolpix camera shows a lens error when turned on...
If the lens is stuck at an angle, you can try and SNAP it back towards the center to straighten it out. If it's not at an angle then the lens needs to be replaced. Sorry I don't have better news than that.
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Is it worth fixing a broken LCD Screen on a Nikon Coolpix L18
That's up to you, of course. You can get a new screen here, but the cost is about the same as a used L18, and not that much less than a new L22 or L24. If it was me, I'd replace the L18 instead of repairing it.
Nikon COOLPIX L18 Digital says lens error!
Sometimes the lens is just stuck, sometimes it needs to be replaced. Try to mechanically move the lens in and out by gently twisting, pushing and pulling. If that fails, the gears are too misaligned to repair it without opening it.
If you're out of warranty, there are third party place that replace them such as camera lens repairs.
If you want to do it yourself, there are also free camera repair guide websites that show you how to replace the lens, the replacement part is usually available on ebay.
My nikon coolpix l18 lcd broked, it stills capture but no picture in lcd only white and the crack thing inside the lcd how can i repair this?
You can't fix a broken LCD, you can only replace it. If you want to do the work yourself, you can order the part here.
Broken screen
You can purchase a replacement screen for around $55.00 in US, or go on ebay for $20.00 and it is shipped from Hong Kong.
http://www.darntoothysam.com/categories/Nikon-Digital-Camera-Parts-and-Repair-Service/Coolpix-L-Series/
19helpful
4answers
Anyone know how to replace the screen on Nikon Coolpix L18?
Once you have all the screws out, seperate from the bottom first and then gently pry at the top sides to break the factory seal. The screen has a thin strip of black tape along the right edge you can pull off. Lift up on the screen to reveal the attached electronic strip attached to the board. It is attached with a grey strip that is hinged, just lift up to remove the strip. Replace with the new screen and reassemble your covers.
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
